I am experiencing problems sending mail using SMTP. I have seen a number of posts from people with similar problems, but I don’t see a clear resolution.
Whenever I try to send an email I receive the following error message:
SMTP Error: Could not connect to SMTP host.
I have validated that I have the appropriate SMTP host and port numbers and I believe that I am using the correct user and password for both the configuration and the emailadmin parts of the site.
Can anyone provide any help troubleshooting this problem?
Thanks
James
