Previously, it was possible to “Insert Into” from the Project list view, now we must go inside the project (Element list) to get this to work. When done from Project list, it crashes here. I’m starting to wonder if I caused this by hiding the project list on the sidebar.
Javascript: No errors or warnings logged
Apache: [Wed Jan 07 14:56:38.027105 2015] [:error] [pid 9991] [client 0.0.0.0:3685] etemplate_new::process_exec(,Array([project_tree] => [nm] => Array([selected] => Array([0] => 5972)[col_filter] => Array()[cat_id] => [filter] => mains[filter2] => active[search] => [sort] => Array([id] => pm_modified[asc] => )[select_all] => [checkboxes] => Array([sources_too] => )[action] => document_PullDocumentSet.odt[${row}] => Array([pm_used_time] => 0[pm_planned_time] => 0)[pml_used_time] => Array([${row}] => Array([pm_used_time] => 0))[planified] => Array([${row}] => Array([pm_planned_time] => 0))[replanified] => Array([${row}] => Array([pm_replanned_time] => 0))))) validation_errors=Array([project_tree] => ‘’ is NOT allowed)!), referer: /egroupware/index.php?menuaction=projectmanager.projectmanager_ui.index&ajax=true
Is this mentioned “project_tree” the project list on Project Manager’s sidebar?
Regards,
Paul.
