Hello!
Yesterday I started adding some minor profiling data to Tine 2.0.
So far I’m really happy.
is json request. method: Tasks.searchTasks
index.php::(47) TIME: 0.18674302101135 seconds 4.25 MBytes
is json request. method: Tasks.saveTask
index.php::(47) TIME: 0.13420104980469 seconds 3.75 MBytes
A json request usualy takes about 0.15 seconds and any process reuqires
about 4 MByte of memory.
I couldn’t collect global timing informations for eGW 1.4, but infolog for
example requires about 25 Mbyte of memory for every request.
Next I will let our admins install APC on this machine. Let’s see if we can
drop the required request time a little bit more.
So far I’m really happy about the values.
You can try to validate this numbers on your own system, if you add
following lines to config.ini:
[logger]
filename = /writeable/path/for/webserver/tine20.log
priority = 7
Lars Kneschke
CTO OfficeSpot.Net
Metaways Infosystems GmbH
our proposal for the next major eGroupWare release: http://www.tine20.org
Web: http://www.metaways.de
Tel: +49 (0)40 317031-21
Fax: +49 (0)40 317031-921
Mobile: +49 (0)175 9304324
