Hi Christophe,
I want to customize columns display in the mail interface and I want it to
be different wether i’m in the inbox or sent directory. What I expect is the
following order of columns.
INBOX Folder
TO - SUBJECT - DATE - SIZE
SENT Folder
FROM - SUBJECT - DATE - SIZE
Is there a way to do so?
That’s fairly easy to do, by editing mail/templates/default/index.xet
containing around line 75ff:
<template id="mail.index.rows" template="" lang="" group="0"
version=“1.9.001”>
<date-time_today align=“center” id="${row}[date]“
readonly=“true”/>
<date-time_today align=“center"
id=”${row}[modified]” readonly=“true”/>
So you would move the to and from colums (2nd and 3rd last) in the
and the two block to first position.
Not wanted columns can be switched off in UI and not used from/to for
sent or not sent folders are switched off automatic.
You need to reload (F5) once you changed the template.
Thanks
Christophe
