you can make a “dump for setup”
OK, but where are they stored in the meantime?
Than you’ll find a etemplates.inc.php in you setup dir.
So, if I edit this file directly, it will make changes to my app?
You need the update script in order to update the tables properly from old
versions. If you don’t have other versions on other systems you don’t need
them.
OK, but I’m not talking about “old” old, I mean if I create a table, and
play with my app for five minutes, then decide to simply change a field in
the table, I will get these other files created. Unfortunately, that makes
it quite difficult to debug after that.
eg. I misspell a field name. When I edit the eTemplate to correct it, the
change to the table is not in the original tables_current file, it is in the
tables_update file. That’s a real pain to debug.
