after a little time I have done a new svn-checkout on a new machine running
debian 7. Nothing special about the installation. I´m using MySQL as
Database, new setup. I have checked felamimail so far and got 3 problems.
- If I open felamimail with the top icon then my folder-tree opens with
INBOX selected, ok so far but no Email is showing up. I have to click on the
INBOX to get my E-Mails shown.
- If I try to setup the application with the lower left menu then I get the
following error:
An error happened
CreateObject(uisettings) file
/var/www/egroupware/preferences/inc/class.uisettings.inc.php not found!
Click here to resume your eGroupWare Session.
Yes, the class-file is not there!
Ok, you are talking about Trunk. That part has been rewritten. FMail
calls the old class instead of linking to it.
You can get FMail preferences working again with the following small change:
Index: felamimail/inc/class.felamimail_hooks.inc.php
— felamimail/inc/class.felamimail_hooks.inc.php (Revision 42440)
+++ felamimail/inc/class.felamimail_hooks.inc.php (Arbeitskopie)
@@ -1073,8 +1073,8 @@
#$mailPreferences =
ExecMethod(‘felamimail.bopreferences.getPreferences’);
$menu_title = lang(‘Preferences’);
$file = array(
egw::link(’/index.php’,‘menuaction=preferences.uisettings.index&appname=felamimail’),
egw::link(’/index.php’,‘menuaction=felamimail.uifelamimail.redirectToPreferences&appname=felamimail’),
if($preferences->userDefinedAccounts ||
$preferences->userDefinedIdentities) {
I’ll talk to Klaus tomorrow, why that special handling was introduced
and he can commit a fix.
- I´m using cyrus IMAP with sieve. I have changed the port to 4190
according to the debian documentation. My sieve-files are named ‘default’.
In my “production” version of egroupware (V1.9.011 on another server with an
older Debian but the same IMAP) I can see and edit my sieve rules.
Btw. I have tested all my browsers on 3 different OS but I have had no luck
in using felamimail with minify, any idea?
minify stopped working, when we switched to asynchronious loading of
scripts. Please switch it off for now.
AlienVault Unified Security Management (USM) platform delivers complete
security visibility with the essential security capabilities. Easily and
efficiently configure, manage, and operate all of your security controls
from a single console and one unified framework. Download a free trial.
http://p.sf.net/sfu/alienvault_d2d
