Ralf,
Just saw the security and bugfix release post so I logged into my
eGroupware server. The commands I issue (via script) is
cd /opt/lampp/htdocs
svn checkout
http://svn.egroupware.org/egroupware/branches/1.8/aliases/default .
I have been doing an SVN checkout for the life of this server, going on
three years now and only recently had an issue. The output of the
update is at the end of this post.
If it helps I can provide the IP address of the server. The time I
tried to connect out was ~7:46am US-PST
Hi Joseph,
Recently logged into my eGroupware machine and issued the svn update
(05/04/2014 ~ 2130PST) command and received the following
Fetching external item into 'egroupware/etemplate’
Checked out external at revision 46807.
Fetching external item into ‘egroupware/phpgwapi’
Authentication realm: http://svn.egroupware.org:80 Read access to
Stylite branches on svn.egroupware.org
Password for ‘root’:
Username: <== Left blank
Password for ‘’: <== Left blank
svn: warning: OPTIONS of
’http://svn.egroupware.org/egroupware/branches/Stylite-EPL-11.1/phpgwapi/inc’:
authorization failed: Could not authenticate to server: rejected Basic
challenge (http://svn.egroupware.org)
Looking at the above line, I don’t have authorization to access the
Stylite-EPL branch. Is there a symlink or other link between 1.8 and 11.1?
Not sure what the issue is.
It could be related to merging new phpgwapi/inc/class.egw_csrf.inc.php
from non-public Stylite-EPL-11.1 branch.
New files sometimes inherit their original rights, even if they are
merged into public 1.8 branch.
I just did an anonymous checkout of phpgwapi, but it worked without problem.
So I’m a bit puzzled what’s the problem here.
Do you still get an error when doing an “svn up phpgwapi” from withing
egroupware directory?
No. ./egroupware/phpgwapi# svn up phpgwapi
At revision 46850.
Do you have above mentioned phpgwapi/inc/class.egw_csrf.inc.php?
No. ./egroupware/phpgwapi/inc# ll class.egw_c*
-rw-r–r-- 1 root root 3757 Aug 31 2013 class.egw_cache_apc.inc.php
-rw-r–r-- 1 root root 3637 Apr 15 2012 class.egw_cache_files.inc.php
-rw-r–r-- 1 root root 22402 Dec 5 2012 class.egw_cache.inc.php
-rw-r–r-- 1 root root 3568 Apr 15 2012 class.egw_cache_memcache.inc.php
(It is used currently only when adding, editing or deleting an account
or change site configuraion, so you might not noticed it missing.)
Fetching external item into 'egroupware/preferences’
It seemed to update ok, eGroupware seems to function ok.
Joseph Hume
F1 for HELP
~# Scripts/updategw.sh
Fetching external item into 'egroupware’
svn: warning: Failed to add file ‘egroupware/anon_wrapper.php’: an
unversioned file of the same name already exists <==This has always been
there
Fetching external item into 'egroupware/admin’
Checked out external at revision 46850.
U egroupware/phpgwapi/setup/tables_update.inc.php
U egroupware/phpgwapi/setup/setup.inc.php
Password for ‘root’: <== Pressed Enter
Username: <== Pressed Enter
Password for ‘’: <== Pressed Enter
Fetching external item into 'egroupware/setup’
U egroupware/setup/setup-cli.php
Fetching external item into 'egroupware/egw-pear’
Fetching external item into 'egroupware/wiki’
Checked out revision 46850.
