I’m Wrong, I must rectify :
Outlook plugin can always read from egw but outlook events are NOT written to EGW even if plugin says “sync ok” with no errors !!!
Sync direction is set to "TwoWay"
Funambol Plugin is v.6.0.7
Any idea ???
Hi
Further data.....
I've created a new calendar in outlook
I've created some few new elements and sync with egw, all works fine
Sync of two previous outlook calendars I tried gone bad, note that these two calendars contain 2-300 elements each
Is there any capability problem (some parameter to increase in egw, php, ecc) ????
Let me know please.
Thank you
Federico
Hi Ralf,
URL is Right, mysite is for hide my personal url
I’ve checked SyncML requirements now
It seems all ok with no error
It remains only one problem
Outlook plugin tells me "all synchronization is succesfully"
But in my personal EGW calendar is totally blank !!!
I’ve also tried a recovery Outlook—>>>EGW but with returncode error -1 from server (probably no more different events to sync)
What can be the matter ???
PHP5 and php5-pear and pear-log are installed
P.S. I’m using EGW rev. 1.2.106 not “1.3 Beta3 or better” as described on info
digiteltlc schrieb:
Hi All
I need do synchronize MS Outlook calendar with my account one in EGW
I’ve found useful Funambol Sync4J plugin
When I use it , I get this error after a regular login to my egw account :
2007-04-11 16:34:19:015 - # Funambol Outlook Plug-in v. 3.0.15
16:34:19:015 [INFO] - Starting synchronization…
16:34:20:375 [INFO] - ********** CALENDAR SYNC ************
16:34:20:375 [INFO] - Synchronization URL: http://mysite/webmail
that url is wrong, try http://domain.com/egroupware/rpc.php (replace
http://domain.com/egroupware/ with your usual eGW URL).
Search our wiki for the SyncML HowTo, it contains that and other
necessary informations.
16:34:20:375 [INFO] - Preparing synchronization of calendar…
16:34:20:703 [ERROR] - Error processing SyncHdr Status
16:34:27:109 [ERROR] - Server Failure: server returned error code -1
16:34:27:109 [ERROR] - Error in syncing: Server Failure: server returned
error code -1
16:34:27:109 [INFO] - Calendar sync completed with errors
16:34:27:125 [INFO] - Logged off from Outlook
Debug log follows :
2007-04-11 16:35:30:812 - # Funambol Outlook Plug-in v. 3.0.15
16:35:30:812 [INFO] - Starting synchronization…
16:35:30:812 [DEBUG] - Enter synchronize method
16:35:30:812 [DEBUG] - Current app dir:
C:\Programmi\Funambol\plug-ins\Funambol Outlook Plug-in
16:35:31:875 [DEBUG] - Enter checkForcedSlowSync method
16:35:31:875 [DEBUG] - Starting readAllFolders procedure
16:35:32:187 [DEBUG] - Exit checkForcedSlowSync method
16:35:32:187 [DEBUG] - Enter loadFoldersProperties method
16:35:32:187 [DEBUG] - folders.preferences does exists. Read
readPreferencesFromFile
16:35:32:187 [DEBUG] - Exit loadFoldersProperties method
16:35:32:187 [INFO] - ********** CALENDAR SYNC ************
16:35:32:187 [DEBUG] - Enter function synchronization…
16:35:32:187 [DEBUG] - Reading configuration settings from the management
tree
16:35:32:187 [INFO] - Synchronization URL: http://www.mysite.com/webmail
16:35:32:187 [INFO] - Preparing synchronization of calendar…
16:35:32:187 [DEBUG] - Initialization message:
16:35:32:187 [DEBUG] - <?xml version="1.0" encoding="UTF-8"?>
1.1
SyncML/1.1
1176302132
1
sc-pim-outlook
b64
syncml:auth-basic
ZnphbmluaTowMjExNjk=
250000
1
200
./sifcalendar
calendar
0
1176302132
16:35:32:187 [DEBUG] - Connecting to www.mysite.com:80
16:35:32:187 [DEBUG] - Requesting resource /webmail
16:35:32:406 [DEBUG] - Message sent
16:35:32:406 [DEBUG] - Reading response...
16:35:32:406 [DEBUG] - Content-length: 4090
16:35:32:406 [DEBUG] - Response read
eGroupWare - Login
#divMain
height:85%;
<!-- this solves the internet explorer png-transparency bug, but only for
ie 5.5 and higher -->
http://www.eGroupWare.org
/webmail/phpgwapi/templates/idots/images/logo.png
| ./phpgwapi/templates/idots/images/spacer.gif |
| eGroupWare |
<table cellspacing="3" cellpadding="0" width="100%" border="0">
<tr>
phpgwapi/templates/idots/images/password.png
<tr>
<td align="right" tablindex="1">Username: </td>
<td align="left"><input name="login" value="" style="width: 150px;
border: 1px solid silver;">
Password: |
phpgwapi/templates/idots/images/valid-html401.png
phpgwapi/templates/idots/images/vcss.png
http://www.egroupware.org eGroupWare 1.2.106
16:35:32:406 [ERROR] - Error processing SyncHdr Status
16:35:32:406 [DEBUG] - CALLBACK: Enter prepareSyncFiles method
16:35:32:406 [DEBUG] - Enter listAllItemsInFolder method
####now all events follow
16:35:32:421 [DEBUG] - AllItemInFolder: Calendario “ITEM NAME” Creation
time: 26/09/2006 14.35.53 Modification time: 16/10/2006 11.22.33
16:35:32:437 [DEBUG] - AllItemInFolder: Calendario “ITEM NAME2” Creation
time: 04/10/2006 11.04.46 Modification time: 06/10/2006 9.00.33
etc.etc. then :
1.1
SyncML/1.1
1176302132
2
sc-pim-outlook
250000
1
1
0
SyncHdr
sc-pim-outlook
200
2
./sifcalendar
calendar
3
text/x-s4j-sife
00000000FBB49CDA08DB984A9CA2584655A1608124796400
b64
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
RE
YXRlPjxOb0VuZERhdGU+MTwvTm9FbmREYXRlPjxQYXR0ZXJuRW5kRGF0ZT48L1BhdHRlcm5FbmREYXRlPjxPY2N1cnJlbmNlcz48L09jY3VycmVuY2VzPjwvYXBwb2ludG1lbnQ+
4
text/x-s4j-sife
00000000FBB49CDA08DB984A9CA2584655A16081046D6400
b64
PGFwcG9pbnRtZW50PjxBbGxEYXlFdmVudD4wPC9BbGxEYXlFdmVudD48U3RhcnQ+MjAwNzA0MTFUMDkwMDAwWjwvU3RhcnQ+PEVuZD4yMDA3MDQxMVQwOTMwMDBaPC9FbmQ+PEJpbGxpbmdJbmZvcm1hdGlvbj48L0JpbGxpbmdJbmZvcm1hdGlvbj48Qm9keT48L0JvZHk+PEJ1c3lTdGF0dXM+MjwvQnVzeVN0YXR1cz48Q2F0ZWdvcmllcz48L0NhdGVnb3JpZXM+PENvbXBhbmllcz48L0NvbXBhbmllcz48SW1wb3J0YW5jZT4xPC9JbXBvcnRhbmNlPjxJc1JlY3VycmluZz4wPC9Jc1JlY3VycmluZz48TG9jYXRpb24+PC9Mb2NhdGlvbj48TWVldGluZ1N0YXR1cz4wPC9NZWV0aW5nU3RhdHVzPjxNaWxlYWdlPjwvTWlsZWFnZT48UmVtaW5kZXJNaW51dGVzQmVmb3JlU3RhcnQ+MTU8L1JlbWluZGVyTWludXRlc0JlZm9yZVN0YXJ0PjxSZW1pbmRlclNldD4wPC9SZW1pbmRlclNldD48UmVwbHlUaW1lPjwvUmVwbHlUaW1lPjxTZW5zaXRpdml0eT4wPC9TZW5zaXRpdml0eT48U3ViamVjdD5nYW4gbWFydGVsbGFnbzwvU3ViamVjdD48UmVjdXJyZW5jZVR5cGU+MTwvUmVjdXJyZW5jZVR5cGU+PEludGVydmFsPjE8L0ludGVydmFsPjxNb250aE9mWWVhcj4wPC9Nb250aE9mWWVhcj48RGF5T2ZNb250aD4wPC9EYXlPZk1vbnRoPjxEYXlPZldlZWtNYXNrPjg8L0RheU9mV2Vla01hc2s+PEluc3RhbmNlPjA8L0luc3RhbmNlPjxQYXR0ZXJuU3RhcnREYXRlPjIwMDcwNDEwVDIyMDAwMFo8L1BhdHRlcm5TdGFydE
Rh
dGU+PE5vRW5kRGF0ZT4xPC9Ob0VuZERhdGU+PFBhdHRlcm5FbmREYXRlPjwvUGF0dGVybkVuZERhdGU+PE9jY3VycmVuY2VzPjwvT2NjdXJyZW5jZXM+PC9hcHBvaW50bWVudD4=
00000000FBB49CDA08DB984A9CA2584655A16081E46C6400
b64
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
Rl
16:35:38:718 [DEBUG] - Connecting to www.mysite.com:80
16:35:38:718 [DEBUG] - Requesting resource /webmail
16:35:38:921 [DEBUG] - Message sent
16:35:38:921 [DEBUG] - Reading response…
16:35:38:921 [DEBUG] - Content-length: 4090
16:35:38:921 [DEBUG] - Response read
eGroupWare - Login
#divMain
height:85%;
| eGroupWare |
<tr>
<tr>
Password: |
16:35:38:921 [ERROR] - Server Failure: server returned error code -1
16:35:38:921 [ERROR] - Error in syncing: Server Failure: server returned
error code -1
16:35:38:921 [INFO] - Calendar sync completed with errors
16:35:38:921 [DEBUG] - Enter restoreSlowSyncBackup method
16:35:38:921 [DEBUG] - Exit restoreSlowSyncBackup method
16:35:38:937 [INFO] - Logged off from Outlook
PLEASE: Any idea about ???
Thank you
Federico
Telefon +49 (0)631 31657-0
opinions on IT & business topics through brief surveys-and earn cash
[/quote]
[/quote]
[/quote]
