“Giuseppe” giu14@interfree.it schrieb:
Which other solutions could I try?
Hello Giuseppe!
There exists no other solution.
You can try to base your work on the syncml codebase. It gives you the
needed synchronisation logic out of the box, but is very complicated to
implement because no syncml client exists currently.
You can base your work on the existing xml/rpc interface. It would make it
very easy to let talk different installations with each other. But the
xml/rpc interface seems to be unmaintained and is not a stable interface as
you are talking with the internal api of the applications directly.
solution and you can’t succeed as long as you can’t work out a good concept
with the eGW core developer.
Lars Kneschke
CTO OfficeSpot.Net
Metaways Infosystems GmbH
our ideas for eGroupWare: http://www.tine20.org
Web: http://www.metaways.de
Tel: +49 (0)40 317031-21
Fax: +49 (0)40 317031-921
Mobile: +49 (0)175 9304324
