Hello,
I try for months now to synchronize one way or another outlook with egroupware.
egwosync fails in most cases and is very unreliable, so I tried syncml with egroupware-1.4.
When I enter the url I get this return :
"You should access this URL only with a SyncML enabled device."
So it looks like syncml is working.
I downloaded the funambol client for outlook (unfortunately it only works with winxp or vista)
and after installing and configuring the funambol client I tried to sync but no result.
It says it finished the sync (log level debug) , no errors are shown but no data whatsoever
is being transported.
The egroupware calendar and contacts of the account contains hundreds of items , I would like to sync to outlook but the egroupware server says nothing is there.
What must be done on the serverside to have syncml actually working?
the sync log on the server :
<?xml version="1.0" encoding="UTF-8"?>
1.1
SyncML/1.1
1182423401
10
http://mail.bhagwato.eu/aarde-werk/rpc.php
fol-VU5FVElYLVhQOkFkbWluaXN0cmF0b3I=
1
9
0
SyncHdr
200
2
9
2
Sync
snote
note
200
[root@mail:/home/saskia/www/aarde-werk]# cat /tmp/sync/syncml_client_1.xml
1.1
SyncML/1.1
1182423401
2
http://myserver/egw4/rpc.php
1
1
0
SyncHdr
200
2
1
9
Alert
scard
contact
200
1182419063
3
1
9
Alert
scal
appointment
200
1182419063
4
1
9
Alert
stask
task
200
1182419063
5
1
9
Alert
snote
note
200
1182419063
6
scard
contact
Thanks
Wim bakker
