Hello
I have some trouble witth syncml functions in EgW.
I try to debug the thunderbird sync with the Tsync ext. At the first time, Tsync did not communicate very well. A devel version is in progress. The two apps do communicate now : adding contacts and delete contacts works
But I find the same problems I have found with Palm sync and Syncml synthesis client : all the fields are not imported and home/work fields (emails and adress) are confused. Synthesis dev told to me that it is because EGW syncml server dysfunction (?).
Debug log show the Vcard as well, withe all home/work fields of thunderbird contacts. But the result is not well at all : onlly work email and home adress in work adress fields…
What must I think and what must I tell to the Tsync dev ? I can continue to work, but I must have some information.
YL
