I’m also try to sync EGW with my new E61.
I added the small code from your mail.
That helps a little bit. Now i can contact between E61 and EGW.
But there is still no sync between the devices.
Could you please help me to get the sync in work?
Dieter
yngwiewrote:
Gabriele,
do you have Everything working on E61?
what version of EGW are you using?
Actually I almost managed to get it working by skipping an empty
block, however contacts sync doesn’t work on the direction
EGW->E61. Opposite works well, calendar works in both directions.
Igor
gturchiwrote:
Hi all. I’m doing some tests for SyncML syncronization. I own a new
Nokia E61 (based on Symbian 9.1 aka Series 60 3rd edition). I needed
to apply a litte patch to make it works:
In file phpgwapi/inc/horde/XML/WBXML/Decoder.php, line 139 (the head
of “decode” function) I added a simple:
if(strlen($wbxml) == 0)
return true;
Apparently the phone sends something like an empty data block, and
the decode function must not fail in this case…
More tests will follow.
Hope this helps.
Bye,
Gabriele
P.S.: I’m sorry, my english is alpha version[/quote:a3f4f0b4fe]
