Hi John,
there’s a patch implementing SyncML 1.2 for EGroupware 1.6.001 (not yet
1.6.002): http://k.noc.de/index.php?option=com_content&view=article&id=6
We are currently working on integrating it into Trunk.
So you have 3 options:
- use 1.6.001 (not recommended because of the security fixes in 1.6.002)
AND that patch
- use 1.6.002 and adapt the patch
- use Trunk
John Thomas schrieb:
A user changed from Palm to Blackberry. The Palm Sync worked great.
The blackberry sync client (I tried both Funambol and SyncJE clients)
will not sync contacts (calendar sync works). I set up debug mode and
it appears the Blackberry client is trying to use SyncML version 1.2
while the Egroupware server is using 1.0. Could this be it? Any
suggestions?
Portion of client debug:
1.2
SyncML/1.2
Portion of server debug:
1.0SyncML/1.0
As an aside, is there a method of exporting contacts from Egroupware as
VCards so i can import them into the Blackberry as a temporary solution
while I debug the SyncML issues?
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Nigel Vickers und Ralf Becker
