Hi Mark,
that’s from my notes of a SyncML install together with Lars:
- You need wbxml binaries.
Wbxml is a binary XML, which gets used by most SyncML devices. There’s a
project on sf.net and some distros have packages for it. As their latest
release is quite old, he recommends a patch version, which is availible
for download from egroupware.org:
http://egroupware.org/other/wbxml.tgz
These are only sources, you need to compile them on your box.
They have to be installed in /usr/bin/{wbxml2xml|xml2wbxml} or you have
to change the pathes in: phpgwapi/inc/horde/XML/WBXML/{Decoder|Encoder}.php
You need PEAR and the PEAR::Log packages.
PEAR is availible for most distros as php{4|5}-pear package and also for
XAMPP. You can use “pear install Log” as root to install the PEAR::Log
if it’s not yet on your computer. For more info see http://pear.php.net
You need to use PHP sessions, it does NOT work with db-sessions!
The device need the following settings (SyncML profil):
URL: http://domain.com/egroupware/rpc.php
of if you use multiple eGW domains:
URL: http://domain.com/egroupware/rpc.php?domain=
User/Password are the same as for eGW
You can sync the following “folders” (mind the spelling):
InfoLog notes: ./notes
Addressbook: ./contacts
Calendar: ./calendar
InfoLog tasks: ./tasks
The calendar still has to be from the “contacts_and_resources” branch.
- Debug information:
SyncML can log the complete xml comunication, if you specify an existing
and by the webserver writeable path in:
phpgwapi/inc/horde/Horde/RPC/syncml.php in var $_debugDir = ‘…’;
For easy debuging you can place that path in the docroot and put an
autoindex script (eg. http://autoindex.sf.net) in it. In that case you
have to secure it with a .htaccess file, as the debug-files contains the
complete xml-comunication including the passwords!!!
The debug code create a directory for each day and device/client
version. That dir contains files with the communication, always starting
with a client request and answered by a server response, which share the
same number in the file-name.
- Recommended SyncML clients:
With mobile phones you have no choice, you can only use the client
delieved with it.
WindowsCE/Mobile, Palm PDA’s or Outlook have no stock SyncML client.
Lars recommends and develops with a comercial client from Synthesis AG
(www.synthesis.ch), it is availible via Lars companies website
www.officespot.de, which also has some more information about SyncML.
You get a 30 day test-version and have to buy a license after that time.
There are free clients from the Sync4j project, but Lars mentioned some
problems with them.
Lars and I plan to make the SyncML stuff a real eGW application, with an
own configuration and preferences:
- for easier configuration (no need to edit the sources)
- better access control (now all eGW users can sync everything they have
read-access too)
- allow to limit the sync on certain categories
- specify a timespan to sync
Mark Owen schrieb:
I would like to test SyncML. I am running 1.0.1.012.
I ran:
cvs update -r contacts_and_resources calendar
cvs co syncml
I now have tables in my database that include syncml in their title.
How do I get the SyncML server running?
From what I can tell it is not available for download yet.
Anyone else have any insight or do we have to wait for the Linux expo?
Mark Owen
SF.Net email is sponsored by:
Tame your development challenges with Apache’s Geronimo App Server. Download
it for free - -and be entered to win a 42" plasma tv or your very own
Sony™PSP. Click here to play: http://sourceforge.net/geronimo.php
