good answer below - I tried to respond previously, but the internets in
indonesia are sporadic
Hey mate, you can see here that this has been discussed before, and it seems
there is yet to be a solution
http://www.nabble.com/Iphone---td21271529.html#a21271529
cheers
L.
Could you explain
- What you have installed in your Iphone : the name of the client
- The confuration proposed in this client
- which protocol is used : icalsrv is not syncml
- The logs in egW server
If you refer to previous posts, I think there is no way to successfully
sync between EgW and Iphone … but perhaps there is solution with
Icalsrv, I don’t know (I have not Iphone …).
YL
kashin a écrit :
Hello,
I’m struggling to syncronise Egroupware with my Iphone.
I’ve try to install the sync ML bu I always receive the “wrong RL” error
message in the client.
I’ve installed the icasrv and it works perfect with Thunderbird.
Do you have an idea how to sync Task, contacts and calendar with my
Iphone?
Thanks for your help!
It is the best place to buy or sell services for
http://p.sf.net/sfu/Xq1LFB
The mythical copyright filter that Google could add to YouTube that would
stop YouTube from hosting copyright-infringing material just doesn’t exist.
If it did, Google could get out of the YouTube business and into the
perfect spam filtering business, and make far more money. YouTube costs a
lot to run, and the audience for it’s a lot smaller than the audience for
perfect spam filtering.
–==|| Cory Doctorow’s Cambridge Business Lecture, given 22nd July, 2008
