Hello all
As you can read below, Synthesis provides now a syncml client for contacts,
tasks and calendar for Iphone.
Somebody knows if it works with EGW (or … can try …) ?
Thanks
Message from Synthesis :
Synthesis Info 2/2009
iPhone calendar sync now possible with Todo+Cal+Sync!
With Todo+Cal+Sync 1.6 - now available on App Store - for the first time
SyncML based calendar synchronisation becomes possible on the iPhone.
Todo+Cal+Sync now contains a full-featured calendar together with the
advanced task management and the proven Synthesis SyncML client technology
for synchronizing calendar, tasks and the iPhone address book, in a single
iPhone application. With this, the iPhone can now be used with any of the
numerous SyncML-enabled collaboration systems, on-line calendar services and
groupware applications available on the market.
The calendar supports colored tags to manage multiple calendars easily. At
any time entries from only one, multiple or all calendars can be displayed
in month, day and list views by simply touching the corresponding colored
tag. Month view gives full visual overview of your schedule - including a
graphical representation of the scheduled time and allday events. For
example, free evenings are visible at one glance - no need to open any
detail views or browse though days.
The tasks manager goes beyond the functionality of most common todo lists,
offering tasks that can have subtasks, colored tags which can be organized
hierachically as well as in free form to manage even very large lists of
tasks, ideas and projects efficiently. Since it’s first release, it has been
improved for speedier editing, quick change of priorities, reorganizing
tasks and subtasks and many more detail refinements.
The built-in Synthesis SyncML client synchronizes calendar, tasks, and the
iPhone address book with any SyncML compatible server of your choice.
At this time, there are two limitations set by Apple’s iPhone SDK: Apple
does not allow to access the internal iPhone calendar, nor sync with iCal,
so the calendar in Todo+Cal works independently from the built-in iPhone
calendar. Second, Apple does not allow reminder alerts. We hope Apple will
lift these restrictions, so we can integrate the functionality.
To learn more about the application, please visit our special
"Todo+Cal+Sync" page which provides a introductionary video for the task
management features and links for downloading a short reference and a SyncML
client manual in PDF format.
The upgrade to Todo+Cal+Sync 1.6 is free for all former customers of
Todo+Sync 1.0 and Todo+Cal+Sync 1.5.
Note for iPhone developers: The synchronisation part of “Todo+Cal+Sync” is
based 100% on our modular SyncML Client SDK. With this, it becomes easily
possible for iPhone developers to equip their own iPhone applications with
mature, high quality SyncML functionality. Just contact us
(info@synthesis.ch) if you are interested in the iPhone version of the
client SDK.
Thank you very much for your attention!
</td>
</tr>
<tr style="height: 4.1pt;">
<td width="228" valign="top" height="33" style="padding: 0cm
5.4pt;">
Yves
Lannehoa
</td>
<td width="236" valign="top" height="33" style="padding: 0cm
5.4pt;">
La
Tourellerie<o:p> </o:p>
</td>
</tr>
<tr style="height: 1.55pt;">
<td width="228" valign="top" height="9" style="padding: 0cm
5.4pt;">
<o:p>
</o:p>
</td>
<td width="236" valign="top" height="9" style="padding: 0cm
5.4pt;">
<o:p>
</o:p>
</td>
</tr>
<tr style="height: 12.25pt;">
<td width="228" valign="top" height="49" style="padding: 0cm
5.4pt;">
Tel : +33 (0) 2 43 88
08 16
GSM : +33 (0) 6 19 07 64 42
</td>
<td width="236" valign="top" height="49" style="padding: 0cm
5.4pt;">
La Tourellerie
72700 ROUILLON
France<o:p>
</o:p>
</td>
</tr>
<td width="228" valign="top" height="21" style="padding: 0cm
5.4pt;">
lannehoa.pro@tourellerie.fr<o:p> </o:p>
</td>
<td width="236" valign="top" height="21" style="padding: 0cm
5.4pt;">
http://tourellerie.dyndns.org
</td>
</tr>
<tr>
<td width="349" valign="top" height="1" colspan="2"
style=“border-style: none none solid; border-width: medium medium 2.25pt;
border-bottom: 2.25pt solid rgb(0, 0, 153); padding: 0cm 5.4pt; width:
348.9pt;”>
