Hi Peter,
I need to check in the sources if that’s possible.
You might check in the generated javascript on the page.
Peter schrieb:
I am trying to develop an application where the edit dialog box contains tabs
within tabs. For example, the dialog box has the tabs:
Tab1|Tab2|Tab3|Tab4|Tab5|Tab6|Tab7
Tab3 contains a template that also has tabs:
TabA>TabB>TabC>TabD>TabE>TabF
First of all, is this even possible? I have tried this and when Tab3 is
selected, instead of seeing TabA|TabB|TabC|TabD|TabE|TabF in the edit box,
the first set of tabs reappears underneath the first set, creating 2 rows of
the same tabs.
Any ideas?
Thanks,
Peter Allen
opinions on IT & business topics through brief surveys – and earn cash
