Peter,
I am using 0.66 SOGO connector. I have tried to find the older versions
0.61 or 0.62 and no luck, so I am stuck or do you know where I can
donwload older versions.
And what do you mean by appropiate applications.
I am using adressbook and calendar in eGroupware and sync them with my
mobile Nokia N70 through rpc.php only one way phone - eGroupware. For
now this is enough. I can see appointment in thunderbird but no
contacts. I am using this link http://myserver.nl/egroupware/icalserv.php
And which error.log do you mean ? Does eGroupware have is own and if so
what is the location.
Can you help me any further
Thanks,
Frans Lieshout
Peter Goerzen schreef:
When I try to contactegw adressbook through this link
http://www.myserver.nl/egroupware/icalsrv/groupdav.php/addressbook/
nothing happens the same problem as described in an other topic of this
forum. The solution mentioned there, getting a older version of Sogo or
unmark line 137 in class.icalsrv_groupdav.inc.php did not do the trick.
Hi Frans,
I’m just now starting to do testing with trunk, but I am able to get it to
work with version 0.62 of the SOGo Connector. I don’t believe that any newer
version will work. (You may get a newer version to read, but you definitely
won’t get it to write.)
Do you have the appropriate application(s) enabled for yourself? I’m not sure
what these would be – maybe addressbook and icalsrv?
Does your error.log file have anything interesting in it?
In case you’re interested, they switched to using the Mozilla WebDAV API in
recent versions of the connector, but this library doesn’t support
the “Location” header for PUT answers. The Inverse folks tell me that this
will be “worked-around” in a future release, but they don’t know when.
Frans Lieshout Financieel BV
BANJOSTRAAT 49
1312KB Almere
NEDERLAND
Tel : +31 (36) 5467722
Mobiel : +31 (6) 22406833
Web : http://www.flfinancieel.nl
Email :info@flfinancieel.nl
BTW NR :
812.54.43.16.B.01
KVK Lelystad : 39083803
De informatie in deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde. Wanneer u dit bericht per abuis ontvangt, verzoekt Frans Lieshout Financieel BV u contact op te nemen met de afzender.
Bovendien verzoekt Frans Lieshout Financieel BV u in dat geval deze e-mail te vernietigen en de inhoud aan niemand openbaar te maken.
Frans Lieshout Financieel BV aanvaardt geen aansprakelijkheid voor onjuiste, onvolledige dan wel ontijdige overbrenging van de inhoud van een verzonden e-mail, noch voor overgebrachte virussen.
