Hi devs,
using trunk at 24963, adding a timesheet to an existing infolog entry. I
recall that in timesheet, general tab one was able to enter a duration then
hit update ignoring the begin-end spec.
This lead to the specified amount of time being taken into the field
"amount".
Today i could not acheive this anymore because timesheet always computes the
diff between the prefilled start date and 23:59, even if duration is
explicitly set.
This isn’t correct, isn’t it?
Sven
