Hello
Now I have my Iphone and I have test the todo+cal client from synthesis. I have notice all tips to make it works :
First, as with synthesis client for Palm, modify the two files :
/calendar/inc/class.calendar_ical.inc.php :
$defaultFields[‘full’]; by default for * case’synthesis ag’ * and for default * ‘// the fallback for SyncML’ * in order to sync categories
/addressbook/inc/class.addressbook_vcal.inc.php :
$defaultFields[1]; by default for * case’synthesis ag’ * and for default * ‘// the fallback for SyncML’ * in order to sync phones numbers
After install the client and calendar app :
Server settings:
- Adress : domain/egroupware/rpc.php.
- Syncml version 1.1
- Ignore ssl errors
- User/pass : id of EgW user
- AND ACTIVE THE LEGACY MODE. without this, contacts will not sync …
Database :
- Path must be ./contacts ; ./calendar ; ./tasks
With these settings, sync works like a charm, without hack of EgW nor Iphone.
Calendar Synthesis app is easy to use after … read the manual …
YL
This SF.net email is sponsored by:
High Quality Requirements in a Collaborative Environment.
Download a free trial of Rational Requirements Composer Now!
http://p.sf.net/sfu/www-ibm-com
