Hi All !
Whikle playing with the Tracking system, i’ve found a strange problem:
If i change fron one label to another, nothing appear
Is enought to change a “Tracker Code” and return to the previous and the lists appear
Same in ACL (for “All” Code)
Not only !!!
If i change a value in “Configuration” tab and save the change, all the flag in ACL label disappear (reset all permission) If i make change and save in ACL tab, all the parameter setup in “configuration” tab will reset to the default.
I hope is only my problem … Please can someone try the same ?
Thanks in advance
