Hi, I´m using egroupware 1.4 and when I tried import some files for
calendar or contacts from MS Outlook using cvs or ical file formats, the
importation fails?
Can you help me ? Has some trick or tips for make this import?
Where I can find more information about these feature in groupware?
I can’t solve your problem, but I can confirm the problem. The problem also
fails in the other directions as well. If you export with icalsrv creating
the “events.ics” file. The events.ics file will not import into Outlook
2003. The import fails and Outlook reports a corrupt events.ics file. So the
format egw is exporting is not compatible with Outlook, so I would suspect
that the format egw is looking for is also not compatible with an ics
export.
David C. Rankin, J.D., P.E.
510 Ochiltree Street
Nacogdoches, Texas 75961
(936) 715-9333
(936) 715-9339 fax
www.rankinlawfirm.com
