Hi.
I’m trying to test the community 1.8, to determine if the fee based
version would be a good bet.
My problems.
I’m trying to install the egroupware app
http://www.egroupware.org/download<<. Given that there is no rpm, I
downloaded the
eGroupware-1.8.001.20101201.tar.gz
eGroupware-egw-pear-1.8.001.20101201.tar.gz
I’m running fedora 13, with the default/stock apache/php/mysql/pear.
I’ve also set the user/permissions for the egroupware files via
find -type f -exec chmod 755 ‘{}’ ;
find -type d -exec chmod 750 ‘{}’ ;
I’ve also modified the apache httpd.conf as required to setup the test
site, and this works as I can see the config page.
The initial configuration page indicates that the required subordinate
functions are installed. The only “warnings” i get have to do with
using a db, that i’m not installing. I’m using mysql for the test.
The next step in the process, would be to initiate, and fill in the
header.inc.php, which is auto generated via the
header_manager.php/form.
However, when I attempt to generate the manageheader.php to invoke the
form, I get a blank page, and the form is never displayed.
I suspected that this might be a user/permission error, but for the
life of me I can’t track it down. Viewing the apache
error_log/access_log didn’t shed any light on this either.
I’ve talked to a few people via the irc egroupware, but was unable to
figure this out.
I’ve narrowed the issue down, using the debug function of php. It
appears that the issue is within the code section of the
manageheader.php file:
$setup_tpl->set_var(‘lang_select’,'
Please
Select your language '.lang_select(True,‘en’)."
Fatal error: Call to undefined function lang_select() in
/var/www/html/egroup/setup/manageheader.php on line 230
The “lang_select” is in the class >>> setup_html <<<
Any potential pointers/thoughts would be welcome!!
I’ve inspected the 1.6 code, and see the same code, so I’m curious as
to what could be causing this issue. Could this be due to some stting
within the php.ini env. On the other hand, I don’t see how the
setup_html class is ever setup to use the lang_select method of the
class.
Thanks
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
