Unable to access Infolog "Invalid input syntax for integer"
I have recently upgraded from 20.1 to 21.1, but when trying to open the Infolog, I get an error:
SQLSTATE[22P02]: Invalid text representation: 7 ERROR:  invalid input syntax for integer: "#4e02d8c4b4679bc9d3dc1cd5d1068cbb"
The docker-compose logs shows:
egroupware-nginx      | 2021/08/04 13:18:16 [error] 23#23: *34597 FastCGI sent in stderr: "
PHP message: An error happened! (PDOException): SQLSTATE[22P02]: Invalid text representation: 7 ERROR:  invalid input syntax for integer: "#4e02d8c4b4679bc9d3dc1cd5d1068cbb"
PHP message: #0 /usr/share/egroupware/stylite/src/Vfs/Versioning/StreamWrapper.php(402): PDOStatement->execute()
PHP message: #1 [internal function]: EGroupware\Stylite\Vfs\Versioning\StreamWrapper->unlink()
PHP message: #2 /usr/share/egroupware/api/src/Vfs/StreamWrapper.php(429): unlink()
PHP message: #3 /usr/share/egroupware/api/src/Vfs.php(726): EGroupware\Api\Vfs\StreamWrapper->unlink()
PHP message: #4 [internal function]: EGroupware\Api\Vfs::_rm_rmdir()
PHP message: #5 /usr/share/egroupware/api/src/Vfs.php(551): call_user_func_array()
PHP message: #6 /usr/share/egroupware/api/src/Vfs.php(706): EGroupware\Api\Vfs::find()
PHP message: #7 /usr/share/egroupware/api/src/Link.php(1347): EGroupware\Api\Vfs::remove()
PHP message: #8 /usr/share/egroupware/api/src/Link.php(710): EGroupware\Api\Link::delete_attached()
PHP message: #9 /usr/share/egroupware/api/src/Link.php(665): EGroupware\Api\Link::unlink2()
PHP message: #10 /usr/share/egroupware/api/src/Link.php(874): EGroupware\Api\Link::unlink()
PHP message: #11 /usr/share/egroupware/api/src/Link.php(917): EGroupware\Api\Link::title()
PHP message: #12 /usr/share/egroupware/api/src/Link.php(600): EGroupware\Api\Link::titles()
PHP message: #13 /usr/share/egroupware/infolog/inc/class.infolog_ui.inc.php(453): EGroupware\Api\Link::get_links_multiple()
PHP message: #14 /usr/share/egroupware/api/src/Etemplate/Widget/Nextmatch.php(611): infolog_ui->get_rows()
PHP message: #15 /usr/share/egroupware/api/src/Etemplate/Widget/Nextmatch.php(184): EGroupware\Api\Etemplate\Widget\Nextmatch::call_get_rows()
PHP message: #16 [internal function]: EGroupware\Api\Etemplate\Widget\Nextmatch->beforeSendToClient()
PHP message: #17 /usr/share/egroupware/api/src/Etemplate/Widget.php(566): call_user_func_array()
PHP message: #18 /usr/share/egroupware/api/src/Etemplate/Widg
This is 21.1 EPL, database = Postgresql
Anyone have an idea on how to resolve this?
I am unable to access my TODO-list using the web interface.
That md5 hash is used for a not (yet) existing attachment directory instead of it’s fs_id.
My guess is MySQL/MariaDB simply returned nothing on that SQL query, while PostgreSQL gives an error and the caused exception aborts the request. I need to reproduce and fix that in the source.
Ralf,
Any update on this?
Is there anything I can do to assist in getting this resolved?
Nope, not yet :frowning:
Please try the following Commit:
To apply a commit to your container, see the following HowTo:
I’m waiting for your feedback, before merging it to 21.1.
Unfortunately, still the same error.
I did:
host .../egroupware-docker # export patch=https://github.com/EGroupware/egroupware/commit/1462fb517a3b75c786394c28fce63a63836ca965.patch
host .../egroupware-docker # curl $patch | docker exec -i egroupware patch -p1 -d /usr/share/egroupware-sources
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  1609  100  1609    0     0   6611      0 --:--:-- --:--:-- --:--:--  7280
patching file api/src/Link.php
host .../egroupware-docker # docker-compose restart egroupware
Restarting egroupware ... done
Then I executed “admin -> clear cache and register hooks” and wiped the browser cache
Sure it’s the same error, and not something similar looking?
Please post the output from /etc/egroupware-docker/egroupware-logs.sh again.
That was not necessary for PHP changes and you already did a container restart / cleared the cache.
The error in the logs is identical (same filenames and line numbers):
2021/08/18 08:16:58 [error] 26#26: *236 FastCGI sent in stderr: "
PHP message: An error happened! (PDOException): SQLSTATE[22P02]: Invalid text representation: 7 ERROR:  invalid input syntax for integer: "#c7e7a1ec4de5cb11e3395b29cea70068"
PHP message: #18 /usr/share/egroupware/api/src/Etemplate/Widget
The only thing that changed is the code that is reported. (This changed not long after I opened this report, but hasn’t changed since)
Just noticed:
When I try to open the “infolog”, I see the following from “egroupware-push” right before the “egroupware” error:
egroupware-push       | Pushed for 2af70f2088bf148480580ba75c3b5d8d634f37d8 to 2 subscribers: {"type":"apply","data":{"func":"egw.push","parms":[{"app":"kanban","id":"4","type":"delete","acl":null,"account_id":1000}]}}
Further update, the reported code changed after deleting a kanban board.
I managed to resolve the issue by doing something a little more drastic. (Did a backup before):
  • Deleted all kanban cards
  • Deleted all kanban boards
  • removed all links related to kanban from the database:
delete from egw_links where link_app1 like '%kanban%' or link_app2 like '%kanban%';
(There were 16 records, but kanban itself was empty)
I can now access the infolog again.
I am not sure how those incorrect egw_links entries appeared. Before deleting, these were the 16 rows:
 link_id | link_app1 | link_id1 |   link_app2   | link_id2 | link_remark | link_lastmod | link_owner | deleted
    2059 | infolog   | 1182     | kanban_column | 4        |             |   1628018555 |       1000 |
    2061 | infolog   | 1183     | kanban_column | 4        |             |   1628018647 |       1000 |
    2069 | infolog   | 1184     | kanban_column | 16       |             |   1628101507 |       1000 |
    2072 | infolog   | 1185     | kanban_column | 13       |             |   1628101703 |       1000 |
    2079 | kanban    | 4        | infolog       | 1182     |             |   1628102460 |       1000 |
    2080 | kanban    | 4        | infolog       | 1183     |             |   1628102465 |       1000 |
    2081 | kanban    | 5        | infolog       | 1173     |             |   1628102476 |       1000 |
    2082 | kanban    | 5        | infolog       | 1172     |             |   1628102480 |       1000 |
    2083 | kanban    | 5        | infolog       | 1168     |             |   1628102488 |       1000 |
    2084 | kanban    | 5        | infolog       | 1124     |             |   1628102504 |       1000 |
    2085 | kanban    | 5        | infolog       | 1129     |             |   1628102504 |       1000 |
    2086 | kanban    | 5        | infolog       | 1128     |             |   1628102504 |       1000 |
    2087 | kanban    | 5        | infolog       | 1127     |             |   1628102504 |       1000 |
    2088 | kanban    | 5        | infolog       | 1125     |             |   1628102505 |       1000 |
    2089 | kanban    | 7        | infolog       | 1185     |             |   1628103057 |       1000 |
    2090 | infolog   | 1182     | kanban        | 7        |             |   1628103734 |       1000 |
Grrt, got the wrong line/statement, please apply the following patch too:
Hmm, not a good idea, as we are now to able to verify the fix works.
Can you try adding infolog cards to a kanban board again or better restore your backup and see if the problem reapears?
And then apply my second patch, to see if it fixes it.
After applying both patches, the error does not occur again.
(This was after restoring the database, eg, with the “incorrect” entries in the “egw_links” table)
Thanks :slight_smile:
I’ll backport it then to 21.1.
I did the deletes only to test a possible cause. Was already planning on restoring to backup to ensure we can test any further patches.
I have deleted the kanban board (was for testing anyway), but am still seeing some entries in the “egw_links” table:
And the kanban tables ( egw_kanban_board , egw_kanban_card , egw_kanban_column ) are empty.
Is it safe to delete those 6 remaining records?
I already asked Nathan (@ngegw) to have a look at your other Kanban topic, please post the question there, as it seems not PostgreSQL related.
