Actually your edits showed up there a couple of times.
Strange. Thanks for getting involved.
20:34:17 +0100
Hi Klaus!
I am trying to comment on the tracker #2431 on egroupware.org (assigned
to you) but I get a white page and the content does not appear in the
tracker item. Can you please try to add the content or check the error
log for the reason?
The current trunk version does not seem to have the problem. If you are
using the redirect.php from tracker 2276: I have updated the file because
it introduced an error, leading back to the home application in my
installation (indicating that your default application seems to be
felamimail).
Note that I can only reproduce the problem from within the tracker mails,
if I configure the system to link to another egroupware hostname than is
used in the mail settings, such that the redirect.php comes into action
in the automatic mails from the tracker application. If I do so, I have
to open another session using the other hostname or I will be redirected
to the login page.
Thanks a lot,
Hans-Jürgen
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon’s best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and
easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
[ open style of IT ]
Morschheimer Strasse 15 | D-67292 Kirchheimbolanden
fon +49 (0)6352 . 70629-0 | fax +49 (0)6352 . 70629-30
email: office@stylite.de Managing Directors Stylite GmbH: Mr. Andre Keller,
Mr. Ralf Becker, Ms. G. Mueller
USt-ID: DE214280951
SteuerNr. 44/667/1114/3
Bank Stylite GmbH: Stadtsparkasse Kaiserslautern, BLZ 540 501 10,account nr.
334 235
IBAN DE87 5405 0110 0000 3342 35 SWIFT MALADE51KLS
VAT Stylite GmbH DE231110012
www.stylite.de
A streamlined, 14 day to market process makes app distribution fast and easy
