Bonjour,
j’ai un problème quand je clique sur “Mail”
C:\wamp\www\egroupware\admin\inc\class.admin_mail.inc.php (175)
Erreur ! Undefined constant “LC_MESSAGES” (0)
Voici le log :
[03-Sep-2025 13:43:46 UTC] EGroupware\Api\Mail::getInstance (299) Loading the Profile for ProfileID failed for icServer; Compte non trouvé ! (acc_id=NULL) Trigger new instance for Default-Profile . called from:EGroupware\Api\Mail::getInstance:299 / mail_ui->__construct:149 / EGroupware\Api\Framework\Ajax::ajax_exec:1121 / call_user_func_array(Array) / EGroupware\Api\Json\Request->handleRequest:205 / EGroupware\Api\Json\Request->parseRequest:106
[03-Sep-2025 13:43:46 UTC] (EGroupware\Api\Exception\WrongUserinput): L’initialisation du courrier en échec. Veuillez utiliser l’assistant pour traiter le problème. (100)
[03-Sep-2025 13:43:46 UTC] File: \mail\inc\class.mail_ui.inc.php, Line: 452
[03-Sep-2025 13:43:46 UTC] #0 C:\wamp\www\egroupware\api\src\Framework\Ajax.php(1154): mail_ui->index()
[03-Sep-2025 13:43:46 UTC] #1 [internal function]: EGroupware\Api\Framework\Ajax::ajax_exec(‘index.php?menua…’)
[03-Sep-2025 13:43:46 UTC] #2 C:\wamp\www\egroupware\api\src\Json\Request.php(205): call_user_func_array(Array, Array)
[03-Sep-2025 13:43:46 UTC] #3 C:\wamp\www\egroupware\api\src\Json\Request.php(106): EGroupware\Api\Json\Request->handleRequest(‘mail.jdots_fram…’, Array)
[03-Sep-2025 13:43:46 UTC] #4 C:\wamp\www\egroupware\json.php(130): EGroupware\Api\Json\Request->parseRequest(‘mail.jdots_fram…’, ‘{“request”:{"pa…’)
[03-Sep-2025 13:43:46 UTC] #5 {main}
[03-Sep-2025 13:43:46 UTC] # Instance=default, User=jean-clement.hennebert, Request=POST ?menuaction=mail.mail_ui.index&ajax=true, User-agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36
[03-Sep-2025 13:43:47 UTC] Erreur ! (Error): Undefined constant “LC_MESSAGES” (0)
[03-Sep-2025 13:43:47 UTC] File: \admin\inc\class.admin_mail.inc.php, Line: 175
[03-Sep-2025 13:43:47 UTC] #0 C:\wamp\www\egroupware\mail\inc\class.mail_wizard.inc.php(32): admin_mail->__construct()
[03-Sep-2025 13:43:47 UTC] #1 C:\wamp\www\egroupware\index.php(138): mail_wizard->__construct()
[03-Sep-2025 13:43:47 UTC] #2 {main}
[03-Sep-2025 13:43:47 UTC] # Instance=default, User=jean-clement.hennebert, Request=GET http://localhost/egroupware/index.php?menuaction=mail.mail_wizard.add&msg=L’initialisation+du+courrier+en+échec.+Veuillez+utiliser+l’assistant+pour+traiter+le+problème.&msg_type=error, User-agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36
Je suis sur Windows 11 à jour, wampserver 3.3.8, Apache 2.4.5.9, Php 8.3.6, Mysql 8.3.0
L’installation en CE est récente 23.1.20250902
Depuis 2008, j’utilise une version qui fonctionne et est maintenant en version 21.1.20230210. Je souhaiterai évoluer.
Merci et belle journée
