If you include that in the restore, I think many users will be happy.
jaytraxx schrieb:
I found one hint on php.net:
$out = preg_replace(’!s:(\d+):"(.*?)";!se’, “‘s:’.strlen(’$2’).’:”$2";’",
$serialized );
$value = unserialize($out);
This re-calclulates every stringlen of every value before giving the string
to unserialize(), means:
a:17:{s:8:“currency”;s:1:“€” …
gets
a:17:{s:8:“currency”;s:3:“€” …
What do you think?
Greetings
christian
jaytraxx wrote:
Hi folks,
I’m currently migrating our EGw from iso charset to utf-8. I do that in
setup with a database export and re-import it with the new system charset.
It’s working mostly fine. The only problem comes up with serialized arrays
(e.g. preferences) which include special characters, like e.g. the € (EUR)
sign.
In ISO, the € (EUR) value is serialized like that:
If I re-import the database now with utf-8 as charset, nothing is changed
on the serialized array on re-import. It remains with
But, the € (EUR) sign in UTF-8 is three chars long and until I don’t
change the value to
all unserialize calls on the string end up with “false”.
Anyone out there having a fix for that is welcome. I just want to avoid
changing all the serialized fields by myself. Maybe there is a possibility
to adjust the value length somehow on re-import time.
Greetings
christian
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
