Hi again!
For me the update procedure doesnt work!
I followed all steps even removed /tmp/egw*
I tried to update from version 1.8.001.20100917(?) to 1.8.001.20111111
The update doesnt work for calendar (access.log):
"GET /gw/index.php?menuaction=calendar.calendar_uiviews.index HTTP/1.1"
500 - “https://…/gw/wiki/index.php” “Opera/9.80 (X11; Linux x86_64; U;
en) Presto/2.9.168 Version/11.52”
or address book:
“GET /gw/addressbook/index.php HTTP/1.1” 302 2
"https://…/gw/wiki/index.php" "Opera/9.80 (X11; Linux x86_64; U; en)
Presto/2.9.168 Version/11.52"
"GET /gw/index.php?menuaction=addressbook.addressbook_ui.index HTTP/1.1"
The update works fine for
- email
- wiki
- resources
- infolog
- gallery
- project manager
- knowledge database
Help appreciated
displayed on webpage during update process:
process->pass(): #1 for upgrade processing
process->upgrade(): Incoming : appname: phpgwapi, version: 1.8.001, status:
process->upgrade(): phpgwapi(1.8.001 --> 1.8.002): running
phpgwapi_upgrade1_8_001() --> 1.8.002
process->upgrade(): Upgrade of phpgwapi to 1.8.002 is completed.
process->upgrade(): Outgoing : appname: phpgwapi, status: C
process->upgrade(): Incoming : appname: admin, version: 1.8, status:
process->upgrade(): Upgrade of admin to 1.8 is completed.
process->upgrade(): Outgoing : appname: admin, status: C
process->upgrade(): Incoming : appname: preferences, version: 1.8, status:
process->upgrade(): No table upgrade required/availible for preferences
process->upgrade(): Outgoing : appname: preferences, status: C
process->upgrade(): Incoming : appname: etemplate, version: 1.8, status:
process->upgrade(): Upgrade of etemplate to 1.8 is completed.
process->upgrade(): Outgoing : appname: etemplate, status: C
process->pass(): phpgwapi skipped on this pass
process->pass(): admin skipped on this pass
process->pass(): preferences skipped on this pass
process->pass(): etemplate skipped on this pass
process->pass(): #2 for upgrade processing
Checking the eGroupWare Installation
Checking required PHP version 5.2+ (recommended 5.2+): 5.2.6-1+lenny13
==> True
Checking php.ini: safe_mode = Off: ini_get(‘safe_mode’)=’’ = Off
Checking php.ini: magic_quotes_runtime = Off:
ini_get(‘magic_quotes_runtime’)=‘0’ = Off
Checking php.ini: register_globals = Off:
ini_get(‘register_globals’)=‘0’ = Off
Checking php.ini: display_errors = Off: ini_get(‘display_errors’)=‘0’ = Off
Checking php.ini: memory_limit >= 24M: ini_get(‘memory_limit’)='64M’
Checking php.ini: max_execution_time >= 30:
ini_get(‘max_execution_time’)='90’
Checking php.ini: file_uploads = On: ini_get(‘file_uploads’)=‘1’ = On
Checking php.ini: upload_max_filesize >= 8M:
ini_get(‘upload_max_filesize’)='64M’
Checking php.ini: post_max_size >= 8M: ini_get(‘post_max_size’)=‘65M’
Checking php.ini: include_path contain .:
ini_get(‘include_path’)=’.:/usr/share/php:/usr/share/pear’
Checking php.ini: date.timezone set and not “System/Localtime”:
ini_get(‘date.timezone’)='Europe/Berlin’
Checking php.ini: mbstring.func_overload = 7:
ini_get(‘mbstring.func_overload’)='7’
Checking php.ini: magic_quotes_gpc = Off:
ini_get(‘magic_quotes_gpc’)=‘0’ = Off
Checking extension session is loaded or loadable: True
Checking extension pdo is loaded or loadable: True
Checking extension mysql is loaded or loadable: True
Checking extension pdo_mysql is loaded or loadable: True
X Checking extension pgsql is loaded or loadable: False
The pgsql extension is needed, if you plan to use a pgSQL database.
XChecking extension pdo_pgsql is loaded or loadable: False
The pdo_pgsql extension is needed, if you plan to use a pgSQL database.
X Checking extension odbc is loaded or loadable: False
The odbc extension is needed, if you plan to use a MaxDB, MsSQL or
Oracle database.
X Checking extension pdo_odbc is loaded or loadable: False
The pdo_odbc extension is needed, if you plan to use a MaxDB, MsSQL or
Oracle database.
X Checking extension oci8 is loaded or loadable: False
The oci extension is needed, if you plan to use a Oracle database.
X Checking extension pdo_oci is loaded or loadable: False
The pdo_oci extension is needed, if you plan to use a Oracle database.
Checking extension mbstring is loaded or loadable: True
Checking extension ldap is loaded or loadable: True
Checking extension ctype is loaded or loadable: True
Checking extension mcrypt is loaded or loadable: True
Checking extension xmlreader is loaded or loadable: True
Checking extension gd is loaded or loadable: True
Checking extension zip is loaded or loadable: True
