Hello
did (system) update on 28.07 included egw update
system sles 11.2 with repository open-suse buildservice included
now I have problems e.g. to add users and more (blank page oder box)
apache tells
[Tue Jul 30 10:35:56 2013] [error] [client xxx] PHP Parse error: syntax
error, unexpected T_PAAMAYIM_NEKUDOTAYIM in
/usr/share/egroupware/emailadmin/inc/class.emailadmin_bo.inc.php on line
884, referer:
https://faui1-calendar.cs.fau.de/egroupware/index.php?menuaction=admin.uiaccounts.list_users
(google says http://johnlamansky.com/tech/t_paamayim_nekudotayim/)
any idea what to do
Try the following patch:
Index: emailadmin/inc/class.emailadmin_bo.inc.php
— emailadmin/inc/class.emailadmin_bo.inc.php (Revision 43202)
+++ emailadmin/inc/class.emailadmin_bo.inc.php (Arbeitskopie)
@@ -880,8 +880,7 @@
($profile[‘defaultQuota’] > 0 || (string)$profile[‘defaultQuota’]
=== ‘0’) &&
stripos(constant($profile[‘imapType’].’::CAPABILITIES’),
‘providedefaultquota’) !==false)
$profile[‘defaultQuota’]);
self::$sessionData[‘profile’] = array();
$this->saveSessionData();
If that works for you, let works for you (not running into any other PHP
5.3 related problems).
Anyway using PHP 5.3 provided in SLES 11 SP2 makes sense anyway. 5.2 is
dead since a long time, new SLES 11 SP3 removes 5.2 altogether.
Get your SQL database under version control now!
Version control is standard for application code, but databases havent
caught up. So what steps can you take to put your SQL databases under
version control? Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=49501711&iu=/4140/ostg.clktrk
