I’m trying to install version 1.6 on Ubuntu 10.04 LTS an import my data from a 1.4 installation on a Debian machine. Database is PostgreSQL in all cases.
First I tried the Ubuntu version 1.6.001. This can import my last 1.4 backup fine (no errors, data shows up in database tables) but I can not login afterwards because of the infamous ‘Session could not be verified’ error. This is the same if I do a clean install or import my old data.
Then I tried version 1.6.003 from the opensuse Ubuntu rep. Now I can login, but I can’t import my old data. Neither the original 1.4 backup nor a backup that I made from 1.6.001 with the old data importet. The error messages on import look like this:
Database error: Invalid SQL: SELECT setval(‘seq_egw_sitemgr_pages’,MAX(page_id)) FROM egw_sitemgr_pages
pgsql Error: -1 (FEHLER: Relation »seq_egw_sitemgr_pages« existiert nicht LINE 1: SELECT setval(‘seq_egw_sitemgr_pages’,MAX(page_id)) FROM egw… ^)
File: /usr/share/egroupware/phpgwapi/inc/class.schema_proc.inc.php
Line: 595
Function: schema_proc::query / schema_proc::UpdateSequence / db_backup::restore
Database error: Invalid SQL: SELECT setval(‘seq_phpgw_mydms_groups’,MAX(id)) FROM phpgw_mydms_groups
pgsql Error: -1 (FEHLER: aktuelle Transaktion wurde abgebrochen, Befehle werden bis zum Ende der Transaktion ignoriert)
Line: 595
Database error: Invalid SQL: SELECT setval(‘seq_egw_emailadmin’,MAX(ea_profile_id)) FROM egw_emailadmin
Line: 595
Database error: Invalid SQL: SELECT setval(‘seq_egw_tracker_bounties’,MAX(bounty_id)) FROM egw_tracker_bounties
Line: 595
and so on.
