Hello all, I am wondering if anyone is able to point me in right
direction.
I am trying to upgrade from eGroupware 1.6 to 1.8 and having problems
when I get to the upgrade process
I go to http://mysite/egroupware/setup and login and select ‘upgrade’,
this work for a little and then fails with the following error
An error happened
calendar_timezones::import_sqlite('calendar/setup/timezones.sqlite')
required SQLite support (PHP extension pdo_sqlite) missing!
I am a little confused as to what should be done here, the server has
never been running sqlite but mysql.
EGroupware uses an SQLite database from Thunderbird for timezone
information, that needs to be imported into MySQL.
So install pdo_sqlite extension and everythings fine.
Details:
Server Ubuntu
egroupware 1.6 to 1.8
Put Bad Developers to Shame
Dominate Development with Jenkins Continuous Integration
Continuously Automate Build, Test & Deployment
Start a new project now. Try Jenkins in the cloud.
http://p.sf.net/sfu/13600_Cloudbees
