Hi there,
as a long term user of 1.8 I’m trying to get to 14.3.
According to check_install.php everything is ok, the database upgrade runs fine without errors.
But after login as user I get:
An error happened
Template home.index not instanciable! Maybe you forgot to rename template id.
Or e.g. in addressbook:
An error happened
Template addressbook.index not instanciable! Maybe you forgot to rename template id.
A restart of apache makes this disappear for a short time, but after some minutes I get this again.
A google search for “Maybe you forgot to rename template id.” gives just two results, both pointing to the egw sourcecode.
Any suggestions where to start searching?
Kind regards and a happy new year
Manuel
