Hi Clemens,
seems I missed that one
Anyway it’s fixed now, please replace
/usr/share/egroupware/api/src/Auth/Sqlssl.php with
https://raw.githubusercontent.com/EGroupware/egroupware/16.1/api/src/Auth/Sqlssl.php
Thanks for reporting the issue
hi,
after cron-apt upgrade to 16.1 I can´t login any more to my egw
installation.
in error.log:
mod_fcgid: stderr: PHP Fatal error: Class
’EGroupware\Api\Auth\auth_sql’ not found in
/usr/share/egroupware/api/src/Auth/Sqlssl.php on line 23
I even can´t find the string auth_sql in /usr/share/egroupware/ -R
except in the class that extends class auth_sql
shouldn´t at least exist the parent class auth_sql?
/usr/share/egroupware# grep auth_sql * -R
api/src/Auth/Sqlssl.php: * @todo rewrite using auth_sql backend class
api/src/Auth/Sqlssl.php:class auth_sqlssl extends auth_sql
api/src/Auth/Sqlssl.php: # if we’re not doing SSL
authentication, behave like auth_sql
thx for any hints!
clemens
