I ran the debian upgrading process to reach version 10.12. (with the usual process, of updating EGroupware release key for Debian 10)
(I am not exactly sure what version it was before that, but after upgrade, Egroupware is 21.1.20220408)
After upgrade and reboot, i was greeted with an nginx error 502.
I took this action : Cannot login after update to 21.1 and now - EGroupware is working again, able to log in and generally functioning.
However, in egroupware/setup pages, in 'check installation, i see a lot errors reported :
Checking required PHP version 7.3+ (recommended 7.4): 7.4.28 ==> True
Passed Checking php.ini: safe_mode = Off: ini_get(âsafe_modeâ)=ââ = Off
Passed Checking php.ini: magic_quotes_runtime = Off: ini_get(âmagic_quotes_runtimeâ)=ââ = Off
Passed Checking php.ini: register_globals = Off: ini_get(âregister_globalsâ)=ââ = Off
Passed Checking php.ini: display_errors = Off: ini_get(âdisplay_errorsâ)=ââ = Off
Passed Checking php.ini: memory_limit >= 128M: ini_get(âmemory_limitâ)='172Mâ
Passed Checking php.ini: max_execution_time >= 30: ini_get(âmax_execution_timeâ)='90â
Passed Checking php.ini: file_uploads = On: ini_get(âfile_uploadsâ)=â1â = On
Passed Checking php.ini: upload_max_filesize >= 8M: ini_get(âupload_max_filesizeâ)=â64Mâ
Passed Checking php.ini: post_max_size >= 8M: ini_get(âpost_max_sizeâ)=â65Mâ
Passed Checking php.ini: allow_url_fopen = On: ini_get(âallow_url_fopenâ)=â1â = On
Passed Checking php.ini: include_path Contain .: ini_get(âinclude_pathâ)=â/usr/share/egroupware/vendor/pear/xml_util:/usr/share/egroupware/vendor/pear/structures_graph:/usr/share/egroupware/vendor/pear/console_getopt:/usr/share/egroupware/vendor/pear/archive_tar:/usr/share/egroupware/vendor/pear/pear_exception:/usr/share/egroupware/vendor/pear/auth_sasl:/usr/share/egroupware/vendor/pear/log:/usr/share/egroupware/vendor/pear/pear:/usr/share/egroupware/vendor/pear/xml_feed_parser:.:/usr/share/phpâ
Passed Checking php.ini: date.timezone Set and not âSystem/Localtimeâ: ini_get(âdate.timezoneâ)=âUTCâ
Passed Checking php.ini: magic_quotes_gpc = Off: ini_get(âmagic_quotes_gpcâ)=ââ = Off
Passed Checking php.ini: mbstring.func_overload = 0: ini_get(âmbstring.func_overloadâ)=â0â = Off
Passed Checking extension session is loaded or loadable: True
Passed Checking extension pdo is loaded or loadable: True
Passed Checking extension mysqli is loaded or loadable: True
Passed Checking extension pdo_mysql is loaded or loadable: True
Passed Checking extension pgsql is loaded or loadable: True
Passed Checking extension pdo_pgsql is loaded or loadable: True
Passed Checking extension mbstring is loaded or loadable: True
Passed Checking extension ldap is loaded or loadable: True
Passed Checking extension ctype is loaded or loadable: True
Passed Checking extension apcu is loaded or loadable: True
Passed Checking extension json is loaded or loadable: True
Passed Checking extension zip is loaded or loadable: True
Passed Checking extension tidy is loaded or loadable: True
Passed Checking extension xsl is loaded or loadable: True
Passed Checking extension xmlreader is loaded or loadable: True
Passed Checking extension gd is loaded or loadable: True
Passed Checking extension bcmath is loaded or loadable: True
Passed Checking extension dom is loaded or loadable: True
Passed Checking extension openssl is loaded or loadable: True
Passed Checking extension xml is loaded or loadable: True
Passed Checking file permissions of /usr/share/egroupware for Not World writable: root/root drwxr-xr-x
This might take a while, please wait âŠ
Error Checking file permissions of /usr/share/egroupware/vendor/npm-asset/dhtmlx-gantt/whatsnew.md for Not World writable: root/root -rw-rw-rw-
^^^^ this directory (/usr/share/egroupware/vendor - doesnât actually exist, checked on file system)
/usr/share/egroupware/vendor/npm-asset/dhtmlx-gantt/whatsnew.md is World writable !
Passed Checking if php.ini setting session.save_path=â/var/lib/php/sessionsâ is writable by the web server: root/root drwx-wx-wt
Error Checking package adldap2/adldap2:v4.0.4 is installed: not installed
Error Checking package bacon/bacon-qr-code:1.0.3 is installed: not installed
Error Checking package bigbluebutton/bigbluebutton-api-php:2.0.9 is installed: not installed
Error Checking package bnf/slim3-psr15:1.1.0 is installed: not installed
Error Checking package bower-asset/cropper:v2.3.4 is installed: not installed
Error Checking package bower-asset/diff2html:v2.9.0 is installed: not installed
Error Checking package bower-asset/fastclick:v1.0.6 is installed: not installed
Error Checking package bower-asset/jquery:1.12.4 is installed: not installed
Error Checking package bower-asset/jquery-touchswipe:1.6.19 is installed: not installed
Error Checking package celtic/lti:v4.4.1 is installed: not installed
Error Checking package components/bootstrap:4.1.1 is installed: not installed
Error Checking package components/jquery:3.3.1 is installed: not installed
Error Checking package composer/installers:v2.1.0 is installed: not installed
Error Checking package container-interop/container-interop:1.2.0 is installed: not installed
Error Checking package defuse/php-encryption:v2.2.1 is installed: not installed
Error Checking package easyswoole/memcache:1.0.1 is installed: not installed
Error Checking package easyswoole/spl:1.3.7 is installed: not installed
Error Checking package egroupware/activesync:21.1.20220408 is installed: not installed
Error Checking package egroupware/adodb-php:21.1.20220408 is installed: not installed
Error Checking package egroupware/bookmarks:21.1.20220408 is installed: not installed
Error Checking package egroupware/collabora:21.1.20220408 is installed: not installed
Error Checking package egroupware/compress:2.3.0 is installed: not installed
Error Checking package egroupware/crypt:2.8.0 is installed: not installed
Error Checking package egroupware/crypt-blowfish:1.2.0 is installed: not installed
Error Checking package egroupware/date:2.5.0 is installed: not installed
Error Checking package egroupware/exception:2.1.0 is installed: not installed
Error Checking package egroupware/guzzlecommon:3.9.3 is installed: not installed
Error Checking package egroupware/guzzlehttp:3.9.5 is installed: not installed
Error Checking package egroupware/guzzlestream:3.9.5 is installed: not installed
Error Checking package egroupware/hstream:1.7.0 is installed: not installed
Error Checking package egroupware/http:2.2.0 is installed: not installed
Error Checking package egroupware/icalendar:2.2.0 is installed: not installed
Error Checking package egroupware/idna:1.2.0 is installed: not installed
Error Checking package egroupware/imap-client:2.31.0 is installed: not installed
Error Checking package egroupware/listheaders:1.3.0 is installed: not installed
Error Checking package egroupware/magicsuggest:2.1.5 is installed: not installed
Error Checking package egroupware/mail:2.7.0 is installed: not installed
Error Checking package egroupware/managesieve:1.1.0 is installed: not installed
Error Checking package egroupware/mapi:1.1.0 is installed: not installed
Error Checking package egroupware/mime:2.13.0 is installed: not installed
Error Checking package egroupware/news_admin:21.1.20220408 is installed: not installed
Error Checking package egroupware/nls:2.3.0 is installed: not installed
Error Checking package egroupware/openid:21.1.20220408 is installed: not installed
Error Checking package egroupware/projectmanager:21.1.20220408 is installed: not installed
Error Checking package egroupware/registration:21.1.20220408 is installed: not installed
Error Checking package egroupware/rocketchat:21.1.20220408 is installed: not installed
Error Checking package egroupware/secret:2.1.0 is installed: not installed
Error Checking package egroupware/smallpart:21.1.20220408 is installed: not installed
Error Checking package egroupware/smtp:1.10.0 is installed: not installed
Error Checking package egroupware/socket-client:2.2.0 is installed: not installed
Error Checking package egroupware/status:21.1.20220408 is installed: not installed
Error Checking package egroupware/stream-filter:2.1.0 is installed: not installed
Error Checking package egroupware/stream-wrapper:2.2.0 is installed: not installed
Error Checking package egroupware/support:2.3.0 is installed: not installed
Error Checking package egroupware/swoolepush:21.1.20220408 is installed: not installed
Error Checking package egroupware/text-diff:2.3.0 is installed: not installed
Error Checking package egroupware/text-flowed:2.1.0 is installed: not installed
Error Checking package egroupware/tracker:21.1.20220408 is installed: not installed
Error Checking package egroupware/translation:2.3.0 is installed: not installed
Error Checking package egroupware/url:2.3.0 is installed: not installed
Error Checking package egroupware/util:2.7.0 is installed: not installed
Error Checking package egroupware/webdav:0.3.6 is installed: not installed
Error Checking package egroupware/z-push-dev:2.5.0.1 is installed: not installed
Error Checking package firebase/php-jwt:v5.2.1 is installed: not installed
Error Checking package gettext/gettext:v4.8.6 is installed: not installed
Error Checking package gettext/languages:2.9.0 is installed: not installed
Error Checking package giggsey/libphonenumber-for-php:8.12.18 is installed: not installed
Error Checking package giggsey/locale:1.9 is installed: not installed
Error Checking package guzzle/parser:v3.9.2 is installed: not installed
Error Checking package lcobucci/jwt:3.4.6 is installed: not installed
Error Checking package league/event:2.2.0 is installed: not installed
Error Checking package league/oauth2-server:7.4.0 is installed: not installed
Error Checking package monolog/monolog:1.24.0 is installed: not installed
Error Checking package nikic/fast-route:v1.3.0 is installed: not installed
Error Checking package npm-asset/as-jqplot:1.0.8 is installed: not installed
Error Checking package npm-asset/dhtmlx-gantt:6.2.7 is installed: not installed
Error Checking package npm-asset/gridster:0.5.6 is installed: not installed
Error Checking package npm-asset/jquery:2.0.3 is installed: not installed
Error Checking package oomphinc/composer-installers-extender:2.0.1 is installed: not installed
Error Checking package paragonie/constant_time_encoding:v2.2.3 is installed: not installed
Error Checking package paragonie/random_compat:v9.99.100 is installed: not installed
Error Checking package pear/archive_tar:1.4.14 is installed: not installed
Error Checking package pear/auth_sasl:v1.1.0 is installed: not installed
Error Checking package pear/console_getopt:v1.4.3 is installed: not installed
Error Checking package pear/log:1.13.2 is installed: not installed
Error Checking package pear/pear:v1.10.12 is installed: not installed
Error Checking package pear/pear_exception:v1.0.1 is installed: not installed
Error Checking package pear/structures_graph:v1.1.1 is installed: not installed
Error Checking package pear/xml_feed_parser:v1.0.5 is installed: not installed
Error Checking package pear/xml_util:v1.4.5 is installed: not installed
Error Checking package php-middleware/log-http-messages:4.0.0 is installed: not installed
Error Checking package phpfastcache/riak-client:3.4.3 is installed: not installed
Error Checking package phpmailer/phpmailer:v6.6.0 is installed: not installed
Error Checking package phpseclib/phpseclib:2.0.31 is installed: not installed
Error Checking package pimple/pimple:v3.2.3 is installed: not installed
Error Checking package pragmarx/google2fa:v5.0.0 is installed: not installed
Error Checking package pragmarx/google2fa-qrcode:v1.0.3 is installed: not installed
Error Checking package psr/cache:1.0.1 is installed: not installed
Error Checking package psr/container:1.1.1 is installed: not installed
Error Checking package psr/event-dispatcher:1.0.0 is installed: not installed
Error Checking package psr/http-message:1.0.1 is installed: not installed
Error Checking package psr/http-server-handler:1.0.1 is installed: not installed
Error Checking package psr/http-server-middleware:1.0.1 is installed: not installed
Error Checking package psr/log:1.1.3 is installed: not installed
Error Checking package robrichards/xmlseclibs:3.1.1 is installed: not installed
Error Checking package simplesamlphp/assert:v0.0.13 is installed: not installed
Error Checking package simplesamlphp/composer-module-installer:v1.1.8 is installed: not installed
Error Checking package simplesamlphp/saml2:v4.5.0 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp:v1.19.5 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-adfs:v1.0.8 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-authcrypt:v0.9.4 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-authfacebook:v0.9.3 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-authorize:v0.9.4 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-authtwitter:v0.9.3 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-authwindowslive:v0.9.1 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-authx509:v0.9.9 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-authyubikey:v0.9.3 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-cas:v0.9.1 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-cdc:v0.9.2 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-consent:v0.9.8 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-consentadmin:v0.9.2 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-discopower:v0.10.1 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-exampleattributeserver:v1.0.0 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-expirycheck:v0.9.4 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-ldap:v0.9.17 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-memcachemonitor:v0.9.3 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-memcookie:v1.2.2 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-metarefresh:v0.9.7 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-negotiate:v0.9.12 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-oauth:v0.9.3 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-preprodwarning:v0.9.3 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-radius:v0.9.4 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-riak:v0.9.1 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-sanitycheck:v0.9.1 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-smartattributes:v0.9.2 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-sqlauth:v0.9.4 is installed: not installed
Error Checking package simplesamlphp/simplesamlphp-module-statistics:v0.9.6 is installed: not installed
Error Checking package simplesamlphp/twig-configurable-i18n:v2.3.4 is installed: not installed
Error Checking package slim/slim:3.12.1 is installed: not installed
Error Checking package steverhoades/oauth2-openid-connect-server:v1.1.0 is installed: not installed
Error Checking package symfony/cache:v5.4.6 is installed: not installed
Error Checking package symfony/cache-contracts:v2.5.0 is installed: not installed
Error Checking package symfony/config:v5.4.3 is installed: not installed
Error Checking package symfony/console:v5.4.5 is installed: not installed
Error Checking package symfony/dependency-injection:v5.4.6 is installed: not installed
Error Checking package symfony/deprecation-contracts:v2.5.0 is installed: not installed
Error Checking package symfony/error-handler:v5.4.3 is installed: not installed
Error Checking package symfony/event-dispatcher:v5.4.3 is installed: not installed
Error Checking package symfony/event-dispatcher-contracts:v2.5.0 is installed: not installed
Error Checking package symfony/filesystem:v5.4.6 is installed: not installed
Error Checking package symfony/finder:v5.4.3 is installed: not installed
Error Checking package symfony/framework-bundle:v5.4.6 is installed: not installed
Error Checking package symfony/http-foundation:v5.4.6 is installed: not installed
Error Checking package symfony/http-kernel:v5.4.6 is installed: not installed
Error Checking package symfony/polyfill-ctype:v1.25.0 is installed: not installed
Error Checking package symfony/polyfill-intl-grapheme:v1.25.0 is installed: not installed
Error Checking package symfony/polyfill-intl-normalizer:v1.25.0 is installed: not installed
Error Checking package symfony/polyfill-mbstring:v1.25.0 is installed: not installed
Error Checking package symfony/polyfill-php56:v1.20.0 is installed: not installed
Error Checking package symfony/polyfill-php72:v1.25.0 is installed: not installed
Error Checking package symfony/polyfill-php73:v1.25.0 is installed: not installed
Error Checking package symfony/polyfill-php80:v1.25.0 is installed: not installed
Error Checking package symfony/polyfill-php81:v1.25.0 is installed: not installed
Error Checking package symfony/routing:v5.4.3 is installed: not installed
Error Checking package symfony/service-contracts:v2.5.0 is installed: not installed
Error Checking package symfony/string:v5.4.3 is installed: not installed
Error Checking package symfony/var-dumper:v5.4.6 is installed: not installed
Error Checking package symfony/var-exporter:v5.4.6 is installed: not installed
Error Checking package symfony/yaml:v5.4.3 is installed: not installed
Error Checking package tinymce/tinymce:5.10.1 is installed: not installed
Error Checking package twig/extensions:v1.5.4 is installed: not installed
Error Checking package twig/twig:v2.14.11 is installed: not installed
Error Checking package webmozart/assert:1.10.0 is installed: not installed
Error Checking package whitehat101/apr1-md5:v1.0.0 is installed: not installed
Error Checking package zendframework/zend-diactoros:1.8.6 is installed: not installed
Passed Checking function imagecreatefromjpeg exists: True
Nevertheless, EGroupware still seems to work correctly. Where do I find these packages?
