AD auth request generate web browser. AD delegate this method to IE or other on Windows. In *nix - must browser manual config.
Old config for NTLM
Apache and PHP configuration for EGroupware using NTLM authentication
This version of EGroupware configuration might not be as up to date as
the one in /usr/share/doc/rpm-build/apache.conf!
Version: $Id: egroupware.conf 35964 2011-08-04 08:37:09Z ralfbecker $
this makes EGroupware available for all vhosts
Alias /egroupware /usr/share/egroupware
iOS 4.3+ calendar requires that to autodetect accounts
RedirectMatch ^(/principals/users/.*)$ /egroupware/groupdav.php$1
<Directory /usr/share/egroupware/phpgwapi/ntlm/>
AuthName "NTLM eGroupWare Authentication"
NTLMAuth on
NegotiateAuth off
NTLMBasicRealm TEST
NTLMBasicAuth on
NTLMAuthHelper "/usr/bin/ntlm_auth --helper-protocol=squid-2.5-ntlmssp"
NegotiateAuthHelper "/usr/bin/ntlm_auth --helper-protocol=gss-spnego"
PlaintextAuthHelper "/usr/bin/ntlm_auth --domain=TEST.LOCAL --helper-protocol=squid-2.5-basic"
NTLMBasicAuthoritative on
AuthType NTLM
require valid-user
<Directory /usr/share/egroupware/>
Options FollowSymLinks ExecCGI
AllowOverride None
Order allow,deny
Allow from all
DirectoryIndex index.html index.php
AddHandler cgi-script .cgi
AddDefaultCharset Off
php_flag file_uploads on
php_flag log_errors on
php_flag magic_quotes_gpc off
php_flag magic_quotes_runtime off
php_flag register_globals off
php_flag short_open_tag on
php_flag track_vars on
php_flag display_errors off
E_ALL & ~E_NOTICE & ~E_STRICT = 8191 - 8 - 2048 = 6135
php_value error_reporting 6135
php_value max_execution_time 90
php_admin_value mbstring.func_overload 7
php_value memory_limit 64M
php_value session.gc_maxlifetime 14400
php_value include_path .:/usr/share/pear
php_admin_value open_basedir /usr/share/egroupware:/var/lib/egroupware:/tmp:/usr/share/pear:/usr/bin/zip:/usr/share/jpgraph:/usr/bin/tnef
php_value upload_max_filesize 64M
php_admin_value upload_tmp_dir /tmp
php_value post_max_size 65M
<Files ~ “.inc.php$”>
Order allow,deny
Deny from all
<Directory /usr/share/egroupware/phpsysinfo/>
<Directory /usr/share/egroupware/gallery/>
php_admin_value open_basedir /usr/share/egroupware:/var/lib/egroupware:/tmp:/usr/share/pear:/usr/bin:/bin
<Location /egroupware/rpc.php>
php_admin_value mbstring.func_overload 0
Order allow,deny
Allow from all
May be ntml config rows exist in real apache config… Check config.
