hello all!
I had setup funambol last year to connect to EGW with Outlook. I have re-instlled EGW, and now cannot get Funambol to work. I have mad sure syncml is checked in the user group.
The funambol client is set to: Location: http://mydumbsite/egw/rpc.php
Username: my-egw-login
Password: my-egw-pw
The results in the funambol log is:
================ SYNCHRONIZATION REPORT ================
SYNCHRONIZATION COMPLETED WITH ERRORS
Last error message = "Error reading HTTP response from Server: received data of size = 0."
Last error code = 2003
Calendar:
Not synced.
13:27:09 GMT -5:00 [INFO] - Outlook session closed successfully.
13:27:09 GMT -5:00 [INFO] - Syncronization process completed with errors (code = 2003).
13:27:09 GMT -5:00 [INFO] - Check on server location for update
13:27:09 GMT -5:00 [INFO] - HttpSendRequest error 12150: The requested header was not found
13:27:09 GMT -5:00 [INFO] - Network error writing data from client: retry 1 time…
13:27:09 GMT -5:00 [INFO] - Network error writing data from client: retry 2 time…
13:27:09 GMT -5:00 [INFO] - Network error writing data from client: retry 3 time…
13:27:09 GMT -5:00 [ERROR] - HTTP request error: 3 attempts failed.
13:27:09 GMT -5:00 [ERROR] - No response from update server
13:27:09 GMT -5:00 [ERROR] - Client update error - uses the stored parameters
13:27:09 GMT -5:00 [ERROR] - update check failed
13:29:28 GMT -5:00 [INFO] - Exiting from Outlook client.
13:54:11 GMT -5:00 [INFO] - Outlook Sync Client opened
Now, one last piece - - the server has SSL cert (fm godaddy) installed and works fine for the software I have installed. To do this, I have these lines added in my ssl.conf file located on /etc/httpd/conf.d folder:
ProxyPass / http://nb1.mydumbsite.org:8080/
ProxyPassReverse / http://nb1.mydumbsite.org:8080/
If anyone can assist in getting Funambol working, or recommend an alternative I would be thankful
