We are just hitting sidebar ‘Elementlist’ link for now…
the behavior is the same in Firefox and Chrome.
How are you opening the project for edit?
Double click on project from project list.
Initial open of project shows the elements fine, but once inside project when you edit an element, right after then is when it does not redraw the elements.
Paul.
I think I have this fixed on my dev copy, should be available in trunk shortly, if not already there.
Nathan
