flushing caches didn’t solve anything. I tried to put at the beginning of class.mail_ui.inc.php
this two lines of code.
ini_set(‘display_errors’, ‘On’);
error_reporting(E_ERROR | E_NOTICE);
And then after login in EGW I can see these errors in apache error log:
PHP Notice: Undefined offset: 1 in /usr/share/egroupware/api/src/Framework/Bundle.php on line 144, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: mail in /usr/share/egroupware/api/src/Framework/Bundle.php on line 87, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: debug_minify in /usr/share/egroupware/api/src/Framework/Bundle.php on line 134, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: resetConnection in /usr/share/egroupware/mail/inc/class.mail_ui.inc.php on line 143, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined offset: 1 in /usr/share/egroupware/api/src/Mail/Notifications.php on line 90, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: connectionTimeout in /usr/share/egroupware/api/src/Mail/Imap.php on line 305, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: mailbox in /usr/share/egroupware/api/src/Mail.php on line 397, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: previewMessage in /usr/share/egroupware/api/src/Mail.php on line 398, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: acc_smtp_username in /usr/share/egroupware/api/src/Mail/Account.php on line 434, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: acc_smtp_password in /usr/share/egroupware/api/src/Mail/Account.php on line 435, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: acc_imap_login_type in /usr/share/egroupware/api/src/Mail/Account.php on line 437, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: mail in /usr/share/egroupware/api/src/Config.php on line 219, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined variable: sR in /usr/share/egroupware/mail/inc/class.mail_ui.inc.php on line 1530, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: header in /usr/share/egroupware/mail/inc/class.mail_ui.inc.php on line 1548, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: header in /usr/share/egroupware/mail/inc/class.mail_ui.inc.php on line 1554, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: tracker in /usr/share/egroupware/api/src/Link.php on line 1081, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined variable: path in /usr/share/egroupware/api/src/Etemplate/Widget/Template.php on line 71, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: is_parent in /usr/share/egroupware/api/src/Etemplate/Widget/Nextmatch.php on line 631, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: is_parent_value in /usr/share/egroupware/api/src/Etemplate/Widget/Nextmatch.php on line 632, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: parent_id in /usr/share/egroupware/api/src/Etemplate/Widget/Nextmatch.php on line 633, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined index: row_modified in /usr/share/egroupware/api/src/Etemplate/Widget/Nextmatch.php on line 373, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined property: mail_ui::$Mail in /usr/share/egroupware/mail/inc/class.mail_ui.inc.php on line 4226, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Trying to get property of non-object in /usr/share/egroupware/mail/inc/class.mail_ui.inc.php on line 4226, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined property: mail_ui::$Mail in /usr/share/egroupware/mail/inc/class.mail_ui.inc.php on line 4227, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Trying to get property of non-object in /usr/share/egroupware/mail/inc/class.mail_ui.inc.php on line 4227, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined variable: result in /usr/share/egroupware/vendor/pear-pear.horde.org/Horde_ManageSieve/Horde/ManageSieve.php on line 708, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
mail_ui::ajax_refreshVacationNotice4232 “Expected a command. Got something else.”, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined variable: ajaxClass in /usr/share/egroupware/api/src/Json/Request.php on line 169, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
PHP Notice: Undefined offset: 1 in /usr/share/egroupware/mail/inc/class.mail_ui.inc.php on line 3546, referer: http://testegw.svkul.cz/egroupware/index.php?cd=yes
I use PHP 7 (according your recomendation for 16.1), and while I work in EGW there is also lot of "deprecated"statement in the error log.
One of them I eliminated. I replaced $digest = Auth_SASL::factory(‘digestmd5’); with $digest = (new Auth_SASL)->factory(‘digestmd5’); in ManageSieve.php . Auth_SASL::factory is deprecated.
Can you help me with any of above stated errors ?
Regards
Luboš
