Hi all,
some applications has vanished from my egroupware CE 14.2.
Today I’ve upgraded from 14.1CE to 14.2CE.
I can’t tell if applications were visible in egroupware side menu before the
upgrade, anyway all applications are marked as installed from the setup menu
(mydomain/egroupware/setup).
They are not visible in all the egroupware accounts. I’ve also tried to add
a new admin account and I can’t see them also in the newly crated account.
For example Filemanager application is installed but i cant see it in the
user side menu.
Any tips or suggestion to fix this strange problem ?
Is there any other place to activate o deactivate EGW applications (apart
the setup menu) i could check ?
That’s only installation of an app, it says nothing about it being
available for a user.
Go to Admin, right click on a group (or less preferable a user) and
select ACL rights. In popup select “Run rights for applications” in
selectbox and add applications.
Thought we do NOT remove run rights on upgrade.
