Hi Ralf and friends!
Norman here, from Canada.
Two questions:
(1) how do I pay for eGroupware EPL ?
(2) how do I define selectbox values within an etemplate ?
I’ve been trying to subscribe to EGW 14.2 and asking Andre how to
proceed (credit card anyone ?) for some time now but I got no answer.
Maybe my mail got lost among some spam or I got a wrong address.
Anyway, could you tell me if there is a credit card payment form I
could use somewhere on the egroupware or stylite web site ?
Otherwise, is there an email address where I could send the card
number and other appropriate data ?
We are speaking of a 1 year subscription for 8 users (we were only
7 employees up till last week), for a non-profit cooperative.
I’ve downloaded 14.2.20150501.tar.gz (seems to be the EPL version)
and I would like to pay for the EPL version, as the application I’m
developing poses me some problems.
My most pressing question (apart from “how to pay”) is this one:
Is eTemplate2 part of the egroupware version I downloaded ?
I’m asking that question because I’ve code snippets as follows in
some of the etemplates for this application:
Choisir
Travailleur
Consommateur
Soutien
non-membre
equipement
The eTemplate editor imports the .xet files with no error messages,
saving them produces no error messages, but re-exporting them gives
this rather different code snippet:
This feels quite strange to me, because the original code is an
almost straightforward copy of what I found in this Feb 14, 2014
message on the egroupware-user list:
Feb 14, 2014; 12:18pm
Re: selectbox values - defined in etemplate
Hello,
I have an text field (Location) in database. I would like to have a
possibility to select from some options to fill this field.
So I would like to choose “selectbox” in eTemplate, and define the
values, that user will be able to select. Is it possible to define the
values, that will be available for selection, directly in eTemplate?
Old eTemplate only allows to set options in code via $sel_options
parameter of etemplate::exec().
New eTemplate2 allows additionally to specify them via template:
All
Some entries
Other entries
So, how do I obtain the same effect (selectbox values defined in etemplate)
as described in Ralf’s answer to Pavel Novák ?
In other words, how do I get to use that eTemplate2 feature ?
Thanks a lot for your answers.
Norman.
Norman Molhant nwm@csur.ca
Coop de Solidarite du Suroit - CSUR
769 Principale, Tres-Saint-Redempteur, Qc
J0P 1P1 Canada
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
