Webdav file creation problem
using gnome to mount webdav shares from EGW (1.8.002) and try to create files in a subdir, there is problem with the lock mechanism.
The problem is in phpgwapi/inc/class.vfs_webdav_server.inc.php (line 445) which calls egw::lock without the option false (check_writable parameter of function lock in ./phpgwapi/inc/class.egw_vfs.inc.php ) as last parameter. Default is true, which means, in front of the file creation process, the file is checked to be writable. But if a new file is created, the file doesn’t exist at this time and thsi prevents the lock which results in an error message and aborts the file creation process.
Please consider to add the patch, which fixes this problem.
webdav.patch (869 Bytes)
Thank you.
S. Wefel
http://egroupware.219119.n3.nabble.com/file/n3295144/webdav.patch
webdav.patch
Thank you.
S. Wefel
I think the patch is the wrong approach, write access is checked to not
allow anyone to lock resources without having the authorization for that.
I would suggest the following:
Index: phpgwapi/inc/class.egw_vfs.inc.php
— phpgwapi/inc/class.egw_vfs.inc.php (Revision 36365)
+++ phpgwapi/inc/class.egw_vfs.inc.php (Arbeitskopie)
@@ -1304,7 +1304,8 @@
static function
lock($path,&$token,&$timeout,&$owner,&$scope,&$type,$update=false,$check_writable=true)
// we require write rights to lock/unlock a resource
  •   if (!$path || $update && !$token || $check_writable &&
!egw_vfs::is_writable($path))
  •   	!(egw_vfs::is_writable($path) || !egw_vfs::file_exists($path) &&
egw_vfs::is_writable(egw_vfs::dirname($path))))
return false;
It checks for not existing files write access to the parent-directory
instead.
Let me know, if that fixes your problem.
Special Offer – Download ArcSight Logger for FREE!
Finally, a world-class log management solution at an even better
price-free! And you’ll get a free “Love Thy Logs” t-shirt when you
download Logger. Secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsisghtdev2dev
I agree, this is a security issue. I had not considered this, because I thought the permission for file creation are checked otherwise and not with the lock function. But you are right, someone could obtain a simple lock command and lock files without permission.
Your lock patch for class.egw_vfs.inc.php fixes the problem too and it is more global nature because it works with other vfs.
Please apply this to the next EGW revision.
Thanks in advance,
S. Wefel
Ok, fix is commited and backport to all branches including 1.8
lock command and lock files without permission. Your lock patch for
because it works with other vfs. Please apply this to the next EGW
revision. Thanks in advance, S. Wefel
View this message in context: Re: webdav file creation problem
http://egroupware.219119.n3.nabble.com/webdav-file-creation-problem-tp3295144p3296100.html
Sent from the egroupware-developers mailing list archive
http://egroupware.219119.n3.nabble.com/egroupware-developers-f278587.html
at Nabble.com.
