In 1.6, you have to use the url you have (groupdav.php in the eGW root)
AND groupdav is an own application, for which you have to give the user
rights, to be able to use it.
The iCalServer stuff (icalsrv directory) is depricated and there a now
fixed problem in 1.6pre1, causing wrong url’s in list.html.
Chris G schrieb:
I’m playing with icalsrv and thus webDAV (groupDav) should be there too.
In the documentation it says the URL is:-
https://example.org/egroupware/icalsrv/groupdav.php/addressbook/
but on my system it’s:-
http://example.org/egroupware/groupdav.php/addressbook/
… and when I go there I get a permission error:-
Permission denied!
You've tried to open the eGroupWare application: groupdav, but you
have no permission to access this application.
#0 /var/www/html/egroupware/phpgwapi/inc/class.egw.inc.php(155): egw->check_app_rights()
#1 /var/www/html/egroupware/phpgwapi/inc/class.egw.inc.php(64): egw->setup(Array, true)
#2 /var/www/html/egroupware/phpgwapi/inc/functions.inc.php(177): egw->__construct(Array)
#3 /var/www/html/egroupware/header.inc.php(135): include('/var/www/html/e...')
#4 /var/www/html/egroupware/groupdav.php(58): include('/var/www/html/e...')
This icalsrv installation in egroupWare is very confusing and messy!
Is there nowhere that documents the current/latest version and how to
install it? For all I know it may be installed by default but nothing
gives me a clue how to find out.
In the egroupWare setup I have added icalsrv and it says it’s
installed OK but that’s about the only positive thing I’ve got so far.
I get the above problems with groupdav and when I go to:-
http://example.org/egroupware/icalsrv/icalsrv.php/list.html/
I just get a blank page.
Do I have to do something to actually export calendars etc. to .ics
files? If so where does it tell me how to do that?
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
cell +49 (0) 170 7815917
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
