Hi Joan,
which Netdrive-version do you use? From my testings the new 2.0.? only
shows something if there are no special chars. Mybe its related to the
used charset (UTF8) which can’t be any longer set in the new client. My
older version 1.?? still works
Birgit
I’ve spent some time searching for an answer for my issue with no luck,
hence the post of a new topic.
I’m one of those wierd guys who installed the community version of
egroupware 1.8.005 in a Windows 2003 server and IIS 6.
Database is a MySQL running on a dedicated server running Centos Linux. In
fact the whole thing is running in a Plesk control panel server (APS
standard installation). PHP is 5.x, FastCGI
And well, so far, so good. But I’m doing a deeper use of this application
and I’m stucked in the following issue:
The filemanager module is working fine. I can upload/download, etc.
Once logged, I can open a new tab in my browser and point to
http:/server/egw18/webdav.php/home/user and see my files and directories
list.
Then I try to connect to my files using the NetDrive app to be able to
manage my files as an ordinary folder in my Windows client computer. I can
connect but there is no list of file to be seen. No error. Just no files.
I pointed the NetDrive program to the demo WebDAV server using the guest
credentials and everything is fine there.
So it seems the problem is in my server/installation.
So where can I get logs or info about what’s the actual problem? Does
anybody have any ideas/clues?
Thanks
Joan
View this message in context: http://egroupware.219119.n3.nabble.com/WebDAV-on-IIS-6-tp3997283.html
Sent from the egroupware-users mailing list archive at Nabble.com.
Learn Graph Databases - Download FREE O’Reilly Book
"Graph Databases" is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/NeoTech
Birgit Becker
Morschheimer Strasse 15 | 67292 Kirchheimbolanden
fon +49 (0) 6352 70629-13 | fax +49 (0) 6352 70629-30
cell +49 (0) 170 3147833
mailto: bb@stylite.de | skype: birgit-kl
Geschäftsführer - Managing Directors: Andre Keller | Ralf Becker |
Gudrun Mueller
Vorsitzender Aufsichtsrat - Chairman of the supervisory board: Prof.
Dr. Birger Leon Kropshofer
VAT DE214280951 | Registered HRB 31158 Kaiserslautern
Germany
"Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free."
http://p.sf.net/sfu/SauceLabs
