Hi!
The problem is even worse if I try to up upload a file starting with an
umlaut, e.g. “Öffentlichkeitsarbeit.txt”:
The whole directory seems empty then in Netdrive,
but in the web frontend, a file “/” or “” has been created.
If you delete this invalid file in the web frontend, all files in that
directory are removed (!), also cleaning the invalid file.
We should definitely take a look after this, I’d suppose, either
prohibiz such files to be uploaded if it is a technical problem between
netdrive and webdav.php or fix the behavior…
Best regards,
Hans-Jürgen
P.S.: This is the message in error.log, when deleting the invalid file
from /home/user/Test-Dateien (an existing directory), which deletes all
directory contents:
sqlfs_stream_wrapper::dir_opendir(‘sqlfs://default/home/user/Test-Dateien’,4)
sqlfs://default/home/user/Test-Dateien is no directory!, referer:
http://localhost/egroupware/index.php?menuaction=filemanager.filemanager_ui.index&path=%2Fhome%2Fuser%2FTest-Dateien
vfs_stream_wrapper::dir_opendir( vfs://default/home/user/Test-Dateien,4)
opendir(sqlfs://default/home/user/Test-Dateien) failed!, referer:
Is it a known problem (I know you did a lot of testing on that) that
file names which I upload through Windows / NetDrive have the file name
stripped after the first special character?
E.g. take a file name “GrößereDatei.txt” and upload it through NetDrive.
The file name is saved as “Gr” in the file manager.
This problem does not exist if I upload the file through the web interface.
Then, the Umlaut displays wrongly in latin-1 / UTF-8 display within
NetDrive.
I can then rename the file, until I change / insert an Umlaut in
netdrive, which again results in the stripped name.
If this is a new problem, I could help investigating on that. There is
nothinǵ related in the error log here. The same problem applies for 1.8
and trunk.
Best regards,
Hans-Jürgen
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today.
http://p.sf.net/sfu/beautyoftheweb
