Is it possible to access work-flow with version 1.8? if so please give me
some guidelines as to how this works.
Thank you.
Just checkout the workflow subdirectory from the egroupware subversion
repository and install it as a normal module.
Do not forget to adjust the setup/setup.inc.php with the new version
numbers.
Üdvözlettel / Kind regards
Pongrácz István
The modern datacenter depends on network connectivity to access resources
and provide services. The best practices for maximizing a physical server’s
connectivity to a physical network are well understood - see how these
rules translate into the virtual world?
http://p.sf.net/sfu/oracle-sfdevnlfb
