Does the anon user have the right to use filemanager, he might be
blocked, because that’s missing?
Hans-Juergen Tappe schrieb:
Hi Ralf!
Ralf Becker schrieb:
I believe this is fixed, can you please re-check (all mentioned cases).
Yes, this seems fixed (besides my failure in using the download module
in public, see german list).
In all three cases, I am asked for credentials and if I give them, the
file download starts and I am logged in.
Thanks for fixing this.
Hans-Jürgen
An error happened with a download module in sitemgr when I migrated to
1.6 (trunk). When I try to download a file, the following error displays:
I played a bit around with downloads and the filemanager:
- When downloading from the sitemgr, I get the error message “Wrong
domain!”
- When entering the URL in a freshly started browser (no session), I am
asked for login credentials. After entering them, I see a blank page
(NO message in the error log). But I am successfully logged in.
- When logged in, it works fine through the application.
What could cause this behavior? Can you reproduce this?
Thanks,
Hans-Jürgen
Wrong domain! ‘’ != ‘default’
#0 /var/www/egroupware/webdav.php(31): egw_session->create(Array)
#1 /var/www/egroupware/phpgwapi/inc/class.egw.inc.php(251):
check_access(Array)
#2 /var/www/egroupware/phpgwapi/inc/class.egw.inc.php(196):
egw->verify_session()
#3 /var/www/egroupware/phpgwapi/inc/functions.inc.php(83): egw->wakeup2()
#4 /var/www/egroupware/header.inc.php(113):
require_once(’/var/www/egroup…’)
#5 /var/www/egroupware/webdav.php(54): include(’/var/www/egroup…’)
#6 {main}
No second domain is configured.
I did not yet dig deeper into this problem; could this be a
configuration or access problem (though I updated header.inc.php) or can
this be reproduced / fixed? I couldn’t see such a config option in the
module’s settings…
When logged in, I can download the respective file…
Thanks,
Hans-Jürgen
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
cell +49 (0) 170 7815917
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
