It looks fine to me. I put that in there with the comments a long time
ago. I thought, at least at the time, that a default format of nothing
would use whatever the system default really is. Whatever works. I say
commit it. Now, does this return the server time, user time, or GMT ?
Hi Ralf, Miles or some other.
I have a small requst… I would like to be able to get the time from the
server through xmlrpc. It looks like someone already have done all the
code, but it seems to commented out…
I have uncommented it, made a little change and tested it. But Im not
much for committing it to the CVS without some php guru giving it a
green light.
So, I have attached small patch… Would someone please have a look at it
and make me happy by commiting it…
Its made with 1.0 version, but it looks the same in 1.2
Cheers
Esben
plain text document attachment (xml_functions.diff)
*** /var/www/untared/egroupware/phpgwapi/inc/xml_functions.inc.php 2005-08-19 14:33:21.000000000 +0200
— xml_functions.inc.php 2005-12-27 08:56:19.172677664 +0100
*** 928,947 ****
$GLOBALS[’_xmlrpcs_egw_time_sig’] = array(array(xmlrpcString,xmlrpcString));
$GLOBALS[’_xmlrpcs_egw_time_doc’] = ‘Returns system time based on optional format string’;
function _xmlrpcs_time($server,$m)
$format = $m->getParam(0);
! $format = $format ? $format : ‘Y/m/d H:i’;
return CreateObject(
'phpgwapi.xmlrpcresp',
CreateObject('phpgwapi.xmlrpcval', date($format,time()), 'string')
/* Add the system functions to the server map */
$GLOBALS['_xmlrpcs_dmap'] = array(
— 928,947 ----
! $format = $format ? $format : ‘Y/m/d H:i:s’;
*** 974,980 ****
‘function’ => ‘_xmlrpcs_phpgw_api_version’,
‘signature’ => $GLOBALS[’_xmlrpcs_phpgw_api_version_sig’],
‘docstring’ => $GLOBALS[’_xmlrpcs_phpgw_api_version_doc’]
‘system.listApps’ => array(
‘function’ => ‘_xmlrpcs_listApps’,
— 974,980 ----
*** 982,994 ****
‘docstring’ => $GLOBALS[’_xmlrpcs_listApps_doc’]
$GLOBALS['_xmlrpc_debuginfo'] = '';
— 982,993 ----
‘system.time’ => array(
‘function’ => ‘_xmlrpcs_time’,
‘signature’ => $GLOBALS[’_xmlrpcs_time_sig’],
‘docstring’ => $GLOBALS[’_xmlrpcs_time_doc’]
