41 / 50
Jul 2020
Only ideas I have:
  • you used an old session, from before you removed the deprecated apps
  • you did not restart our container, which copies the deprecated code inside
I’m not using Docker.
Can I clear cache from egroupware and restart my lighttpd server
After doing some debugging, I found that not all update queries fail for the access log.It fails at some point when accessing the default app page. I set the default app page to filemanager and this is the sequence of logs
UPDATE egw_access_log SET session_dla=1596116842,session_action=’/api/categories.php’,lo=NULL WHERE sessionid=4289950
UPDATE egw_access_log SET session_dla=1596116842,session_action=’/api/config.php’,lo=NULL WHERE sessionid=4289950
UPDATE egw_access_log SET session_dla=1596116842,session_action=’/api/images.php’,lo=NULL WHERE sessionid=4289950
UPDATE egw_access_log SET session_dla=1596116842,session_action=’/api/user.php’,lo=NULL WHERE sessionid=4289950
Instance=default, User=vish, Request=POST https://project.com/egroupware/json.php?menuaction=filemanager.jdots_framework.ajax
When this request is issued, the query fails, the table definition array returns empty and thus no arguments in the query are passed
UPDATE egw_access_log SET WHERE
UPDATE egw_access_log SET session_dla=1596116843,session_action=’/api/lang.php’,lo=NULL WHERE sessionid=4289950
UPDATE egw_access_log SET session_dla=1596116877,session_action=’/index.php’,lo=NULL WHERE sessionid=4289950
An error happened! (EGroupware\Api\Exception\AssertionFailed): CreateObject() file /home/www.tempstop.com/public_html/egroupware/api/inc/class…in
Not sure what the error corresponds here
Instance=default, User=vish, Request=POST https://project.com/egroupware/json.php?menuaction=filemanager.jdots_framework.ajax>
UPDATE egw_access_log SET WHERE.
Please advice. I cleared the cache from the Clear Cache and register hooks option in the setup and even restarted the server. Also I’m using an incognito window
I was removing the deprecated code in my custom application on my local server. After doing the upgrade on production I moved the modified class files of the application. I have also restarted the upgrade several times to get rid of the errors, but nothing changes.
I’m doing through composer with the following steps
  • composer create-project --prefer-source --keep-vcs egroupware/egroupware
  • Copy the custom application in egroupware folder
  • Copy the header file in egroupware
  • Run the db migrations to upgrade
I was using 17.1 version before and with the composer command I got upgraded to the latest version 20.1 which turned out well on my local server which was used for testing but not on production
Is there a way to comment updating the access log update queries ?
I don’t understand the question.
Do you want to comment out the access log update?
The code is the following:
The top 2 arrays are the SET and the lower one is the WHERE. How they can be empty is a mystery of your installation, unless you call set_app() on the global DB object, that would produce something like that.
The arguments are only empty when loading the default application page, rest all update queries run perfectly as shown in my previous messages containing the logs.
