1 / 3
Mar 2023
Hello everybody,
Changelog 23.1.20230328
  • Safari/iOS: support Safari/iOS 14.x via transpiling of JavaScript
  • Home: get home mostly working again
  • All apps: multi-selections eg. searching and entering mail addresses close now automatic on selecting a result
  • Infolog: Remove height restriction on start/due/completed dates in list
  • Mail: fix mail preview don’t get set correctly when running in expand pane view
  • Mail: fix mail preview can not show attachments for smime encrypted messages
  • NewsAdmin: fix creating of new categories
  • WebAuthN: fix not working registration of new authentication devices or browsers
  • Notifications: deal with “Lock timeout exceeded” error on too many undeleted notifications
  • Rocketchat: fix rocketchat’s status sometimes is not showing up in Status app for bigger installations
  • Status: add new config setting in order to be able to open BigBlueButton calls in separate window with no iframe
  • Status: fix top header (invite button, end call button, …) in call dialogs no longer is visible
  • Status: fix ringing tone never ends after a call being answered
  • Status: fix somehow not found user in contacts stalls whole display of status column
  • Api/MariaDB/MySQL: fix SQL error handling in PHP 8.1
  • Admin/Setup: logging all DB backup operations to a text file db_backup.log in backup-directory
  • LDAP/Univention: periodic account-import for Univention (mailPrimaryAddress), use LDAP account-filter for reading accounts too
  • full list of changes 23.1.20230314…23.1.202303286
:warning: This Maintenance update is provided via Docker container.
:uk: Manual (container) update/downgrade in a Docker installation
:de: Manuelles (Container)-Update/Downgrade in einer Docker-Installation
With this update we support iOS from version 14.
When selecting/searching for addresses/users, the search now closes after the selection.
When addressing an e-mail, the arrow can be used to enter further addresses after the first one:
Or you can use the down arrow key.
It is now possible to have BBB calls open in a separate window:
Diff: 21.1.20221202…21.1.20230210
in chronological order.
Many greetings
Your EGroupware team
  • created
    Mar '23
  • last reply
    Apr '23
  • 2
  • 790
  • 1
    user
  • 4
    links
pinned globally Mar 28, '23
14 days later
unpinned Apr 12, '23
