1 / 3
Jul 2023
Hello everybody,
Changelog 23.1.20230728
  • fix some regressions introduced in last maintenance release, see8
:warning: This Maintenance update is provided via Docker container.
:uk: Manual (container) update/downgrade in a Docker installation
:de: Manuelles (Container)-Update/Downgrade in einer Docker-Installation
  • fix some regressions introduced in last maintenance release, see diff8
We had to publish an update of the update at short notice because serious errors had crept in.
in chronological order.
Many greetings
Your EGroupware team
  • created
    Jul '23
  • last reply
    Aug '23
  • 2
  • 697
  • 1
    user
  • 1
    like
  • 4
    links
pinned globally Jul 28, '23
1 month later
unpinned Aug 30, '23
